Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Nov 2010
    Posts
    653
    Marshall Texas
    Kubota L4400
    Default Ford 4600 coolant leak....
    ok... my BIL has a Ford 4600 with the diesel engine.... he is telling me that its got a major coolant leak at a freeze plug at the rear of the cylinder block. He took it to a local guy that told him the tractor would have to be split to fix it.... ?????
    I haven't seen it yet, but he's telling me that he can SEE the freezeplug!!!!.. I'm thinking that if I can see it, it can be repaired/replaced without splitting it?
    Am I completely off base here?
    Has anybody had to make this repair before? Tips or tricks???
    Thanks...
    Kubota L4400 GST
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,436
    Lincoln County, NC need new avatar!
    Just a Scag
    Default Re: Ford 4600 coolant leak....
    Let him split the tractor and replace all 3 plugs in the back of the head & block. If the plug in the head is leaking, the two in the block are equally or more corroded than the upper one that he can see. There are no tricks or shortcuts here.
    Spring is the season of optimism.
  3. #3
    Join Date
    Nov 2010
    Posts
    653
    Marshall Texas
    Kubota L4400
    hhmmm... well, in that case, he should probably just get rid of the tractor, its pretty much used up anyway... thanks for the info....
    Kubota L4400 GST
  4. #4
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    3 freeze plugs and you are ready for the guy to get rid of it? wow... that's a standard maint item. albiet hard ones to get to.. but core plugs are meant to be replaced.. not to be permanent..
    besides.. you'd be surprised at how much work you can get out of a used up tractor.
    here's my 4600. bought it cheap-cheap and go the clapped out mower for free... had no muffler .. flap cap was right on the hood... 3pt position control was not working, no grill or gauges or working electrics.. .. shutoff cable was broke.. had to kill it at the pump
    put in a few weeks of elbow grease and sweat.. got her beat into shape. casted some front weights.. made up a bumper and grill guard, finally added a canvas topper.. but then found a rops.. added the rops, then built a topper for the rops.
    so mows like nobodies business.
    soundguy
    Attached Thumbnails Attached Thumbnails Ford 4600 coolant leak....-a33453-jpg   Ford 4600 coolant leak....-a33609-jpg   Ford 4600 coolant leak....-a35630-jpg   Ford 4600 coolant leak....-a35798-jpg   Ford 4600 coolant leak....-a40012-jpg
    Ford 4600 coolant leak....-a40273-jpg
  5. #5
    Join Date
    Nov 2010
    Posts
    653
    Marshall Texas
    Kubota L4400
    Quote Originally Posted by Soundguy View Post
    soundguy
    oh trust me... its not ALL thats wrong with this tractor... I cannot even begin to tell you how many times Ive welded on the front end. He's sheared the spindle assemblies off several times, blew the bearings out of the front end. I put a brand new spindle assy. in the left front one time, and he bent it the very next week, had to cut an incision, heat it, bend it back into position, and weld the gap back up... I gave up on t=replacing the spindle bearings all the time and actually sleeved it with pipe to re-enforce the spindle housing.... I had to weld the rod ends to the tie rod cause he kept pulling them out.. It needs another clutch, the loader has actually pulled the upper eyes out of the loader arms... (still need to weld them up for him!) He has been using this tractor/loader for his tree business, using the loader to pick up and haul LARGE tree sections and using it to push around a 100 hp. stump grinder... so its been USED!! Of course, the thing has been leaking coolant so long, it hasnt had any antifreeze for probably 3 years, just gets water poured in, been overheated countless times.. so bad that all the oil seals have failed on the engine. Its getting to where the engine has to be hosed down with ether when its hot to get it restarted....
    Maybe this will be the thing that will put the final nail in its coffin!!!
    Kubota L4400 GST
  6. #6
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    sounds more like abuse than use. he needs an industrial machine not a farm tractor..
    soundguy
  7. #7
    Join Date
    Nov 2010
    Posts
    653
    Marshall Texas
    Kubota L4400
    soundguy
    yes sir.... to say the least.....
    Kubota L4400 GST
  8. #8
    Platinum Member sawtooth's Avatar
    Join Date
    Sep 2007
    Posts
    902
    soundguy
    Hello Soundguy,
    I'm looking at a Ford 4600 right now thats with its second owner. He has had it 20 plus years and mentioned the tractor had to be split apart to repair the freeze plug at one point in time. Is this a bad sign that should make me walk away? i'm just worried that maybe they never ran antifreeze and or inhibitors and the inside of the coolant passages are severally corroded with possible wear through etc. Thoughts?
  9. #9
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    be glad that it has already been done.. the hard to get to core plugs are almost always ONLY serviced when they leak. many forget to do them when split for a clutch.
    On a diesel ford I'd like to have known it was run with coolant addatives that prevent cavitation.. however.. there's no way to tell on that one.
    like most used items. you are throwing the dice.
    may be a peach and never have a cavitated pinhole. may blow water into a jug the 2nd day you own it... no way to tell on that one...
    souNdguy
    sent from my NOKIA LUMIA
  10. #10
    Join Date
    Sep 2007
    Posts
    902
    Default
    Ok so Im going to look at it this weekend. When I look it over and run the tractor is there anything I should look for? I'm pretty good at the general stuff like sound and feel of engine, feel of shifter when changing gears, power steering, checking pto, checking lift, power steering, how quickly it cranks, color of smoke etc.
    Thanks
Similar Threads
  1. Yanmar Engine Coolant Leak
    By GCLL in forum Yanmar
    Last Post: 01-30-2011, 04:01 PM
  2. Gator w/ Yanmar Coolant Leak
    By GCLL in forum ATVs & Utility Vehicles
    Last Post: 01-30-2011, 02:48 PM
  3. Ford 4000 Rear Axle Leak
    By BAG in forum Parts/Repairs
    Last Post: 12-29-2009, 07:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
