Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    Aug 2011
    Posts
    5
    1993 Ford/NH 2120
    Default 2120 tire question
    hey folks,
    i'm a newbie here, and to the world of tractors...
    i bought a 2120 for my little slice of heaven and got a 2120 with turf tires at a golf course auction.
    i have hilly terrain and need new front tires. i need ag tires to climb my pasture hills for mowing, but am not sure what size to get. the back turf tires are ok for now (won't use during rain anyhow), but really need the fronts changed.
    i know about keeping the ratio and stuff like that, but am not sure how to order tires. the tire measurements are 27x8.5, but am also assuming (from reading on here) that the rim size is 15"?
    if this is the case, i just need to look for 27x8.5-15 tires? i would like to change the rear tires eventually, but am not sure they make an ag tire that wide with such a small rim diameter...but if anyone has info on that as well that would be great!!! :-)
    thanks all, and have a great weekend (since today is friday).
    bj
  2. #2
    Elite Member mostly_gas's Avatar
    Join Date
    Sep 2009
    Posts
    3,753
    Texas
    in-between tractors
    Default Re: 2120 tire question
    You need to watch the tire outside dia.(OD) as well, just because the side wall numbers are the same does not mean mean the the OD is the same.
  3. #3
    New Member
    Join Date
    Aug 2011
    Posts
    5
    1993 Ford/NH 2120
    do you mean the measurements from the manufacturer of the tire or physically measuring?
    i know the rear tires have no diameter sizes on them. just the rim size it seems.
    thanks.
    bj
  4. #4
    Join Date
    Sep 2009
    Posts
    3,753
    Texas
    in-between tractors
    physical measuring. You will need to tell whoever you are buying the tires from what you are doing so they can help. If you get the tire OD wrong it will get expensive
  5. #5
    Join Date
    Mar 2010
    Posts
    218
    Northcoast, CA
    New Holland TC29D
    I take it that the tractor is used in FWD. If it is 2WD, then I don't see a problem (but then, my eyesight isn't what it used to be!)
  6. #6
    New Member
    Join Date
    Jan 2006
    Posts
    11
    here is what is listed at tractordata dot com
    Ford 2120 Tires:
    Ag front: 8.00-18
    Ag rear: 13.6-24
    If you have turfs on now, to go to ag tires, you will need new to you rims as well.
    this is assumming you have MFWD, to keed the ratios matched.
  7. #7
    Gold Member
    Join Date
    Apr 2001
    Posts
    404
    Southeastern Mass
    New Holland 1920
    Firestone makes an 18.4-16.1 R-1 Ag tire.. All the major tire manufacturers publish complete sprcs including rolling circumfrence and overall diameter. I have the same size turf tires on my NH 1920 and found that the R-1 ag tires were 14.9-24 and 8-16 fronts. I found a pair of used rear rims and 14.9-24 R-4 industrial tires. The matching front tires are 10-16.5, 31 inch OD. Ford/NH never made a 16.5 rim so I am going to mount 31-10.50-15 mud tires on my existing rims. This will keep the lead/lag the same. Bill C
  8. #8
    Join Date
    Jan 2002
    Posts
    837
    Tidewater VA.
    Ford '92 2120
    I used 6 ply bobcat tires for the front. They are R4 tread pattern. 27/8.5x15. The outside dia. is within 1/4" of the stock tires. I bought them from Tucker's Tire Here is a listing for them.
    2 27/8.50x15 BOBCAT LOADER 10 PLY SKIDSTEER TIRES | eBay
    Attached Images Attached Images
    Steve...
    "My biggest fear is that when I'm gone my wife will sell all my tractor gear for what I said I paid for it. "
  9. #9
    New Member
    Join Date
    Aug 2011
    Posts
    5
    1993 Ford/NH 2120
    thanks for all the replies.
    i was on the Firestone website and found the rear ag tires as well.
    the front find is great!! i think i'll buy them. my fronts are in real bad shape anyhow. THANKS.
    my rears are ok for now, but think i will have to buy the ag rears down the road...just not looking forward to the price .
    i have my flail coming in soon so the tractor needs to be running...
    thanks all.
    bj
  10. #10
    New Member
    Join Date
    Aug 2011
    Posts
    5
    1993 Ford/NH 2120
    shaley,
    by 1/4" difference...was it smaller or larger by 1/4"?
    just wondering.
    thanks.
    bj
Similar Threads
  1. Really Weird Tire Losing Air Issue
    By RWEST in forum Tires
    Last Post: 02-04-2007, 10:05 AM
  2. tire swap question on farmtrac 270
    By Ryan03 in forum Tires
    Last Post: 12-01-2006, 07:24 PM
  3. Tires Newbie tire changing question
    By bangtree in forum Yanmar
    Last Post: 05-27-2002, 09:41 PM
  4. Tire ballest question
    By EdKing in forum Tires
    Last Post: 04-15-2002, 08:06 AM
  5. Tire Question
    By Steve_S in forum Kubota Owning/Operating
    Last Post: 03-22-2001, 03:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
