Anonymous Poster
- Joined
- Sep 27, 2005
- Messages
- 0
Hi all: Although this might be posted under attachments/build it yourself, since it is painted blue will do it here. If needs to be moved I guess it can. Since eventually I will be using my TC40 with loader only (right now I am mostly doing BH stuff which gives plenty of rear weight), since I will need a counterweight to offset a loaded bucket, since I wanted something less bulky than a large implement in the rear (as a counter weight), since the weight bar/weights sold by NH run a lot for a cheap SOB like myself I had a 3pt counterweight made up. It uses a straight barrel which is around 8.2 cubic feet. Gravel weighs about 2500 pounds per cubic yard (dry). So, filled, I will have around 750 pounds of easily attached, and compact counter weight to offset the front weight. If I need more weight, I can use scrap iron. The cost? The barrel was free for the hauling, the 3pt hitch bar I had laying around (I think they are only about $10 or so new), 2 cans of "Ford Blue" paint was $8, it will use a couple dollars of gravel to fill and I paid a machinist $50 to weld it up (my welding is between poor and pathetic). So, for around $75 I have a simple, cheap, quick and easy to attach compact rear weight that will do as well as the $300-$450 set-up that NH sells. I will be doing one for the front eventually built similarly but with jacks (similar to camper jacks) to hook over the front when the loader is not on. I am enclosing a pic of the finished counter weight ready to add the weight. JEH
