Lessons learned:
1) Order the gaskets for the sediment bowl too.
Manual says service the sediment bowl with the filter, filter only comes with enough gaskets for itself. (Parts cost, always a battle, and I'm guessing more than a few guys don't touch the sediment bowl, at least not every time).
2) Careful with the big gaskets for the top/bottom of the bowl, filter - they are not the same ! I figured that I needed 2 drain plug gaskets (safe bet, at this vintage), but as it turned out, the biggest reason that the sediment bowl assembly was often damp was that the previous owner had swapped the top and bottom housing gaskets. (Top one, on my '92, is smaller than the bottom one).
Surprisingly, with old gaskets and top/bottom swapped, that only the tiniest amount of seepage was happening - woulda chased this down sooner, had I known....
3) Bleed process is quick/effective. One bleed screw on the filter housing, one on the pump body.
Had the sediment bowl off twice (see #1, above), filter housing apart once. Both times, was able to bleed the air out first shot - and I'm usually not that lucky.
One more thing done on the Fall To Do List.
D.
D.
