Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 49
  1. #1
    Member 401FordManNZ's Avatar
    Join Date
    Mar 2010
    Posts
    30
    New Zealand
    Fords
    Default Ford 3000 Loader Install
    Hi All, I am wanting to install a loader on my ford 3000, the one I have on offer is currently on a ford 5000, the question I have is the loader mount on the bellhousing the same between the two models, I am aware the front cradle is completely different,but if the dimensions are the same for the bellhousing then I can easily fab up the front end and run a support to the rear axle to save snapping the tractor in two.
    1977 Ford 6600 w/Ford 401 Engine, 1968 Ford 3000 Diesel, 1994 Massey Ferguson 375
    "The farmer is the only man in our economy who buys everything at retail,
    sells everything at wholesale and pays the freight both ways. John F. Kennedy
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,438
    Lincoln County, NC need new avatar!
    Just a Scag
    Default Re: Ford 3000 Loader Install
    Bellhousing mounts are the same. Distance from the ground to the mount points are probably quite different.
    Spring is the season of optimism.
  3. #3
    Join Date
    Oct 2006
    Posts
    753
    Thumb, Mich
    Does your 3000 have the expanding shoe brakes or wet disc brakes (I'm not remembering when the change was made). If the latter the rear mounting would be the same. As Rick points out you'll be closer to the ground. Also, the front wheel spindles will be the weak point.
    The Opti-Mist
  4. #4
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Quote Originally Posted by Opti-Mist View Post
    3000 has the outboard brakes and radius rod front axle shared on all the previous models.
    4000 65+ started the inboard brakes..
    soundguy
  5. #5
    Gold Member
    Join Date
    Jan 2007
    Posts
    377
    Ky
    TC55DA
    We have a 3000 with a 730 ford loader 60" bucket . We have broken many front spindles and front end parts over the years . Just dont push it hard with a load .
    A 3400 front end is stronger and will withstand more .
    Ours has a cast oil pan and a subframe that ties from the pan to the rear axe housing at the fender u bolts to keep it together .
    TC55DA 270TL ,Harley rake,Grader box ect ect ect
  6. #6
    Join Date
    Oct 2006
    Posts
    753
    Thumb, Mich
    Quote Originally Posted by Soundguy View Post
    soundguy
    Later on the 3600 got the inboard brakes in basically the 4000 rear end. Later versions of the 3000 were generically referred to as 3000s as well leading to some confusion. I've found it necessary to ask some leading questions to make sure what we're talking about.
    The Opti-Mist
  7. #7
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    uh.. i'm pretty sure the 3600 brakes were the plain drums too.( there also were hyd options ) you may be thinking of a 4000SU or 4600SU they have the rear of a 4xxx essentially, yet the LD front of the 3000. I believe the 3610 also had mechanical outboard drum brakes, and the 3910 had the inboard brakes.
    soundguy
  8. #8
    Join Date
    Mar 2010
    Posts
    30
    New Zealand
    Fords
    Yep she has the plain old drum brakes, I intend to run a frame to the rear axle and pick up on two of the bolts where the linkage arm stabilizers are as I have seen numerous 2,3xxx plain broken in half where the gearbox flange bolts to rear end. I guess I must have to set the relief valve on the loader so it won't be pushed to lift any huge weights, What do you think around 1000 pounds? It will mainly just get used to load stock feed trailers with meal
  9. #9
    Member
    Join Date
    Jul 2011
    Posts
    27
    Ford 3000
    Default
    I have a 74 ford 3000 with a case front end loader. Had to fab all the bracket for bellhouse and rear axel hook up. Have not had any front end trouble as of yet approximate 5 years use on it. Will post some pics tommorow
  10. #10
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    Quote Originally Posted by 401FordManNZ View Post
    1000# will be low for a loader, even with no subframe. I use 1-arm ford loaders and even those, with only 1 trans support, and 1 front support are rated for 1200#
    soundguy
Similar Threads
  1. Ford 3610 w/aftermarket loader
    By Zym in forum New Holland Owning/Operating
    Last Post: 11-01-2011, 02:52 PM
  2. Rotary Cutter bush hog 2400 qt loader on Ford 860
    By tbutcher in forum Attachments
    Last Post: 11-06-2009, 07:10 AM
  3. Front loader - Ford I9-I18...specs and parts?
    By Specop_007 in forum Attachments
    Last Post: 08-25-2009, 01:18 PM
  4. Ford 4000 hydraulic's for loader
    By AlanB in forum New Holland Owning/Operating
    Last Post: 05-31-2008, 01:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
