Results 1 to 9 of 9
  1. #1
    Join Date
    Apr 2008
    Posts
    83
    NE Pa
    Ford/NH 1715
    Default 1715 3 point hitch
    Hi all,
    I tried this in the general parts forum but got no response so will try here. I haven't had to replace any 3 point parts on my NH 1715 until now, so i don't know whats out there. I bought a new rear blade for the tractor and it required an adjustment on the 3 point stabilizer chains but the turnbuckles are frozen solid on both sides. I twisted and cracked the metal on the eyebolt trying to budge them. This looks like an item that should be plentiful in the aftermarket trade but I dont know. Online searches haven't been very fruitful. Can anyone tell me if this is just a generic type of item that I can just get at any Tractor Supply? It certainly looks like it should be. The ones I've seen sold online look to cost about $75 for a pair. Is that about right? Seems kind of expensive. Thanks.
  2. #2
    Join Date
    Aug 2011
    Posts
    134
    Ford/New Holland 1715
    Default Re: 1715 3 point hitch
    I have the same model 1715 and I have been buying parts from Messick's online. I first go to the New Holland USA website for the part numbers (their sight loads and works easier for the numbers and drawings) then I write down the part numbers and plug them into the Messick's site for availability and price. The parts for the turn buckle setup that you are looking for can be purchased individually and yes they are like most other tractor parts very expensive. If you are looking to replace with aftermarket you want to make sure that they have some type of a load rating, there is quite a bit of force applied when using some implements. I looked on the McMaster-Carr website and you would pay about the same but the size would be off some and if you need to replace the end that bolts to the lower arm you would have to buy from the dealer. Depending on which part is broken you might be able to have it welded. For the future get some lube on the threads of the turnbuckle (lube is a lot cheaper than replacing parts).
  3. #3
    New Member
    Join Date
    Oct 2010
    Posts
    20
    Minden, Nevada
    1995 Ford/NH 1715
    Quote Originally Posted by Kosmo View Post
    Hi all,
    You might just measure it and check with a local tractor dealer and see if they have a similar piece.
    Search "side link". I saw a few on ebay for around $25-40.
    The best investment I made was adding the hydraulic top and tilt kit to my 1715. It completely replaces the turnbuckles with a cylinders. I have three levers, top, side-to-side tilt and ripper teeth up/down.
    1995 Ford 1715 w/ 7108 FEL and 60" Gearmore box w/ 3 way hydraulic.
  4. #4
    Join Date
    Apr 2008
    Posts
    83
    NE Pa
    Ford/NH 1715
    Jetskier,
    Would that hydraulic kit allow for tilting implements etc., I bought my back blade with tilting notches so I could cut ditches. The holes for tilting however don't give you much play. How much does a setup like that cost?
  5. #5
    Join Date
    Apr 2008
    Posts
    83
    NE Pa
    Ford/NH 1715
    Wow,
    Just priced the replacement parts for this stabilizer. This thing is less then a foot long and weighs less than a half pound and they charge $163 for the components to replace one of them (Don't even sell tham as a complete unit). I don't care what anyone says, that's obcene. How do farmers survive! This is as bad as getting raked by the drug companies. Who, doing the kind of work that requires these machines, can afford those prices. I can take my busted ones to a fabricator and have them fix them for way less than that price.
  6. #6
    New Member
    Join Date
    Oct 2010
    Posts
    20
    Minden, Nevada
    1995 Ford/NH 1715
    Wow,
    Just priced the replacement parts for this stabilizer. This thing is less then a foot long and weighs less than a half pound and they charge $163 for the components to replace one of them (Don't even sell them as a complete unit). I don't care what anyone says, that's obscene. How do farmers survive! This is as bad as getting raked by the drug companies. Who, doing the kind of work that requires these machines, can afford those prices. I can take my busted ones to a fabricator and have them fix them for way less than that price.
    I paid $1000 for a 60" Gearmore Box Scrapper and the hydraulic kit (installed). That included the box, three cylinders, 3 lever spool, hoses, and the tap into the system. It can pivot about 25ー each way side to side. I think the side link cylinder is about 8". Top is about 12".
    I'm sure you can add the hydraulics alone for under $500-600. Like I said it's nice not to have to get off the tractor to make adjustments.
  7. #7
    Join Date
    Apr 2008
    Posts
    83
    NE Pa
    Ford/NH 1715
    Thanks for the pic Jetskier. Nice!
  8. #8
    Veteran Member jimmysisson's Avatar
    Join Date
    Jul 2005
    Posts
    2,344
    W.Mass
    1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
    Jetskier - how does the top-tilt setup keep you from needing sway limit chains? What stops the lower arms from swinging into the tires? Does your box blade have some other provision for that limiting?
    Jim
    "Anything worth doing is worth doing slowly" Mae West
  9. #9
    New Member
    Join Date
    Oct 2010
    Posts
    20
    Minden, Nevada
    1995 Ford/NH 1715
    Quote Originally Posted by jimmysisson View Post
    Jim
    I still have the limiting chains, but I was just offering info on making adjustments on the fly with his blade since he was starting to replace parts on the 3 point system.
Similar Threads
  1. Agco ST30X 3 point hitch bleeding down
    By swamptiger626 in forum Hydraulics
    Last Post: 09-22-2011, 11:32 PM
  2. 3 point hitch grapple
    By Lt220 in forum Build-It Yourself
    Last Post: 04-09-2011, 11:47 PM
  3. 3 point hitch float
    By RedRock in forum Mahindra Owning/Operating
    Last Post: 11-30-2010, 12:06 AM
  4. 3 point hitch width
    By georgia jeff in forum Attachments
    Last Post: 11-17-2010, 07:08 AM
  5. Mowing 3 point hitch when mowing
    By bad 1k in forum John Deere Owning/Operating
    Last Post: 06-05-2010, 07:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
