Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Jul 2011
    Posts
    22
    Ford 3000
    Default 479 haybine
    I have an old 479 Haybine that I hit a low stump with. Now I can't get the sickle to go back in. Before the crash I noticed a lot of heat building up on the sickle. What gives?
  2. #2
    art
    art is offline
    Super Member
    Join Date
    Apr 2000
    Posts
    5,852
    central New York
    all makes and models
    Default Re: 479 haybine
    Sounds like some gaurds might need some adjusting or replacing. You might have a bent cutter bar but lets try it by adjusting the gaurds up or down to get the cutter bar back in and sliding free.
  3. #3
    Elite Member 5030's Avatar
    Join Date
    Feb 2003
    Posts
    4,866
    Michigan, S.E. Monroe County
    Kubota M9000 Hyd shuttle/Massey 1085
    +1 on Art's comment. NH sickle bar bines have adjustable guards and one or more are too tight. One reason I prefer the SCH design. The guards are rigid. Adjustment is self compensating.
    You might also have a problem with the back ledger. If it was worn, the 'crash' could have pushed the backside of the cutter sections up on top of the ledger. That binds the sickle, creates heat and causes the bar to squeak.
    Kubota M9000HDCC3
    Kubota 105S
    "If haying was easy, everyone would do it. It isn't."
  4. #4
    Veteran Member zzvyb6's Avatar
    Join Date
    Dec 2006
    Posts
    2,324
    michigan
    jd 1070
    Make sure the knife bar is straight and square. Then make sure the guards all line up. I find that you can do the job easier if you raise the driven end up about 2 - 3 feet above the level of the cutter pan when you shove it in. I've been known to wack it in with a hammer at a few steps along the way. Be sure to watch out that the knives don't slide above the stone guard caps. It sure helps if there is another person available to watch during the knife insertion to make sure you are all lined up/down and in/out.
    If the stone guards don't line up in a level line, use a long piece of 1-1/2" pipe to bend them back into position.
    Attached Thumbnails Attached Thumbnails 479 haybine-pic00070.jpg   479 haybine-pic00067.jpg
    There is no "I" in team, but there is a "Me" if you want to jumble it up a bit...
  5. #5
    New Member
    Join Date
    Jul 2011
    Posts
    22
    Ford 3000
    thanks all
Similar Threads
  1. NH 479 haybine belt replacement???
    By newbee83 in forum Parts/Repairs
    Last Post: 05-26-2012, 09:11 AM
  2. NH 479 haybine in good shape - value?
    By acesario in forum Buying/Pricing/Comparisons
    Last Post: 05-10-2011, 07:41 PM
  3. yet another newbie Haybine question NH 479
    By Dave5264 in forum Attachments
    Last Post: 12-05-2009, 03:34 PM
  4. Towing my Haybine over a Narrow(ish) Bridge
    By Dave5264 in forum Owning/Operating
    Last Post: 11-26-2009, 12:54 PM
  5. NH 479 haybine?
    By disco in forum New Holland Ag Tractors
    Last Post: 05-22-2009, 09:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
