Results 1 to 6 of 6
  1. #1
    Member
    Join Date
    Nov 2008
    Posts
    45
    Stockbridge, MI
    John Deere 401C
    Default 1974 Ford 3400- Loader Questions
    My 3400 has a good heavy duty front end loader on it with a front mounted PTO pump. I need help identifying what loader it is? There are two numbers stamped on the side seperated by the Ford symbol. Top one reads 291496 or 291486 and the bottom reads 172. What fluid is used? Where do I add fluid (if needed)? I know the resevoir is in the posts in the back and there is a vent in the top of the LH one. Is that where I add? Where do I check the level? It has no leaks but I want to be sure it's all hunky dory. What is the lifting capacity?
    Thanks.
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,573
    Lincoln County, NC need new avatar!
    Just a Scag
    Default Re: 1974 Ford 3400- Loader Questions
    It is probably a 730 loader. Look for a data plate in the inner side of one of the loader arms, near where the rod end of the lift cylinder mounts. Oil level is 10-12 inches below the fill cap/ breather with the loader bucket flat on the ground.
    Spring is the season of optimism.
  3. #3
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,254
    Central Ohio
    Kubota MX5100
    Post some pics and we can probabally help identify
    There were a few versions of industrial loaders that could have been used. But the 730 was (i think) the most common and the one made for it.
    If the link works, does the frame look like this? 19-498 FRAME ASSY.
    As to the lift capacity, I am not sure if it was ever published, but you will probabally not find ant info on it. But it is an indusrtial loader, so it is probabally a lot. And unless you have a BH on it, or some other form of 2000lb hanging off the back, I dont think you will ever run out of lift capacity. You will just lify the back of the tractor if the item is too heavy.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  4. #4
    Gold Member CTPhil's Avatar
    Join Date
    Nov 2009
    Posts
    282
    NW CT
    The lift capacity on my 735 loader is listed as 3770 lbs. Those industrial loaders are beasts.
    Ford 2600, Ford 4100, Ford 3550, IH 560, IH 460U, 1949 Case VAC, 1951 Case VAC, assorted Gravely L Models, Gravely C10, Gravely 524, Gravely 5460...
  5. #5
    Member
    Join Date
    Nov 2008
    Posts
    45
    Stockbridge, MI
    John Deere 401C
  6. #6
    Join Date
    Apr 2008
    Posts
    18,254
    Central Ohio
    Kubota MX5100
    It does indeed look like a 730 loader.
    That vent IS where you ad the fluid.
    Dont fill it clear full. The oil will need room to expand when it gets warmed up.
    As to the fluid, I am sure ford spec'd their own oil. But you can use any universal hydraulic fluid and be just fine. Like the traveller stuff at TSC. Because all the fluid does is go through a pump and cylinders. It doesnt mix with the transmission/rear end fluid like on a lot of tractors. That fluid has to be specific because ot the clutches, wet brakes, etc.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
Similar Threads
  1. Front loader - Ford I9-I18...specs and parts?
    By Specop_007 in forum Attachments
    Last Post: 08-25-2009, 12:18 PM
  2. Ford 1910/770B loader questions
    By harromeo in forum New Holland Owning/Operating
    Last Post: 02-23-2007, 06:43 PM
  3. FORD LOADER
    By KJO in forum New Holland Owning/Operating
    Last Post: 03-23-2006, 10:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
