Results 1 to 4 of 4
  1. #1
    Join Date
    Jan 2005
    Posts
    152
    Jennings,LA
    Case IH D40
    Default want to install a temp. gauge on D40 tractor like DX models
    I want to install a OEM temp. gauge on a D40 but can not get any help from local dealers on what part or parts I need. They have a temp gauge I can install on the instrument cluster but I am sure I need the thermostat and sending unit. Can anyone help. All the D40 has rite now is the idiot light. I know Jinman can help out. I am calling you out Jinman. Please help if you can.
  2. #2
    Join Date
    Jan 2012
    Posts
    168
    Long 360
    Default Re: want to install a temp. gauge on D40 tractor like DX models
    If the D40 has a place blocked off its possible.
    You need to look at the instrument cluster for both to see what is different.
    Then look at the 2 sending units for size.
    On the thousand series Fords the sender is too small but some have drilled and re tapped to use common temp gauges. Then its just mounting the gauge.
    I am currently adding a after market tach Into ( same spot ) a 72 Chevy C20 with the deluxe instrument cluster.
    I can buy a cluster w tack for 500-1000.00 but the higher ones has the vac gauge too.
    The Main cluster is the same,
    The plastic over the gauges is different, the main metal housing inside is different. the rear metal cover is different, the printed circuit is different.
    Some of these differences can be modified to make work, some cant and you need the right part.
    Of course you can hang a bracket and use aftermarket, or even a gauge pod like some of the 60's muscle cars that had gauges mounted on the hood or cowl.
    Ds
  3. #3
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Quote Originally Posted by Big_Lug View Post
    Well, it might be simple and it might be difficult. Let me cogitate a bit and I'll get back to you tomorrow with some details. I'll try to stay away from tellin' sea stories and fairy tales.
    Cogitation complete: here's the problem. The instrument panel for your economy tractor uses different pin numbers on its connector for the temperature idiot light than the deluxe model uses for the temperature gage. Even if you change the whole instrument panel and put in the resistive sensor on the engine, it will still not work.
    Your engine currently has a temperature controlled switch. When the engine heats up enough, the switch closes and provides a ground to the light circuit in your instrument panel. That light is on the left side of the panel as you view it from the operator station. The signal from the switch enters the instrument panel on pin #7 of the connector. That means that not only is it coming into pin #7 on the instrument, but the harness that connects to the instrument panel also has the wire from the switch attached to pin #7. In the deluxe model tractor, the signal from the temperature sensor comes in on pin #15. I think pin #7 is unused, on the deluxe panel, but I didn't search every connection to see for sure. I'm also pretty sure that your instrument panel mating circuit board is not configured for the plug-in temperature gage like the deluxe model is. You can't plug one in on the economy tractor and the deluxe panel uses different plugs in the connector.
    I really can't recommend making the extensive (and expensive) modification it would require to make this work like the deluxe tractor. I'd suggest finding a suitable location for an after-market gage and then install its temperature sensor in place of the temperature switch. That's the best solution in my opinion. Then, anyone who owns your tractor in the future will not pull their hair out trying to figure out how the tractor has been uniquely modified.
    Sorry it isn't an easy swap. I kinda suspect CNH designed it to be difficult on purpose.
    Jim
  4. #4
    Join Date
    Jan 2012
    Posts
    168
    Long 360
    Sea Story's and Fairy tale's Ha!
    Please note the 2" shorter steering column too.
    Attached Thumbnails Attached Thumbnails want to install a temp. gauge on D40 tractor like DX models-dscf0635-jpg   want to install a temp. gauge on D40 tractor like DX models-dscf0636-jpg
Similar Threads
  1. 2400 temp gauge
    By DEWFPO in forum Massey Ferguson Owning/Operating
    Last Post: 03-31-2011, 07:39 PM
  2. New(to me) YM2210 & temp gauge install
    By mostrander in forum Yanmar
    Last Post: 10-27-2008, 08:24 PM
  3. New Guy...B6100E Aftermarket Gauge Install Qs..
    By Conn in forum Kubota Owning/Operating
    Last Post: 01-11-2008, 03:08 PM
  4. How to install a temp gauge?
    By Gamemaster in forum Kubota Owning/Operating
    Last Post: 01-29-2007, 05:40 PM
  5. Replies: 1
    Last Post: 03-08-2004, 01:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
