FarmerAlan
Hi guys, I'm new here. I recently bought a 71 Ford 2000 3cyl. 6 speed with lift problems. The lift was only working part of the time, and very slowly when it did work. However, it would hold up my heaviest implement, a disc harrow, without leaking down the least bit over several hours. I pulled the lift cover off the tractor and drained the fluid to find that I had some really nasty sludge in the bottom of the case that was clogging up the strainer(s) for the hydraulics. The pto shaft and lever had to be pulled out before the intake strainer could be pulled out. I poured in some kerosine and started wiping the mess out. After going through several dozen towels, I noticed that oil was seeping out of the transmission back into the hydraulic/differential case. It appears that I have a bad seal between the transmission and the hydraulic/ differential case. It looks like replacing the seal would require splitting the tractor, which I'd really like to avoid, if possible. If I'm not mistaken, both the hydraulic system and the transmission can use 134 oil, so is there any reason I couldn't just clean this thing out, replace my gaskets and o-rings and fill up both the transmission and the hydraulic system up with fresh 134, and go on with my life? Thanks in advance, Alan
