Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    Feb 2012
    Posts
    5
    Blandford, Ma
    NH 2120
    Default 2120 PTO stops and starts
    Own a NH 2120 with HSS that I bought new in 1997. Great machine but lately the PTO pops in and out when running an implement. If I push clutch in and out it will come back. Any ideas on what the fix is? Thanks.
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 2120 PTO stops and starts
    do you have to shift the pto back in, like it became disengaged? or merely pushing the clutch in and releasing pedal fixes it?
    soundguy
  3. #3
    New Member
    Join Date
    Feb 2012
    Posts
    5
    Blandford, Ma
    NH 2120
    Just depressing the clutch brings it back. Sometimes it take a couple of tries, then the PTO works fine.
  4. #4
    Join Date
    Jan 2012
    Posts
    617
    Winchester Ky
    Allis Chalmers ED 40
    If the engagement lever does not jump back to neutral, it's probably not a gear related problem. There is a one way sprag clutch in the PTO drive train that could have an issue. Looks like it's in the rear housing, under the 3 Pt lift housing. Don't know what you use the tractor for, but this sprag would only come into play when decelerating with a high momentum load on the PTO. A built-in over running clutch.
  5. #5
    New Member
    Join Date
    Feb 2012
    Posts
    5
    Blandford, Ma
    NH 2120
    When this problem started, I had my log winch on the tractor. When I engaged the PTO (at idle), it turns for a short while then just stops with no load. The PTO lever does not go back to neutral. Sometimes the PTO comes back on its own and sometimes I need to depress the clutch and it comes back. When the PTO is turning, it works fine.
  6. #6
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    when it comes on.. does it pull full power.. or slip?
  7. #7
    New Member
    Join Date
    Feb 2012
    Posts
    5
    Blandford, Ma
    NH 2120
    Full power with no slipping when it works.
  8. #8
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,535
    Lincoln County, NC need new avatar!
    Just a Scag
    Quote Originally Posted by DickG View Post
    Your sprag is shot.
    Spring is the season of optimism.
  9. #9
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    i can remember reading about some kubota subcuts that had an ORC delete kit you could put on them to combat multiple failures... I havn't heard much about fnh units failing though.. do you see alot of this?
  10. #10
    Veteran Member whodat526's Avatar
    Join Date
    Apr 2010
    Posts
    1,529
    deridder louisiana
    fords
    Quote Originally Posted by Soundguy View Post
    i changed three of them last year on 1715 fords
Similar Threads
  1. JD 2440 PTO Stops Turning
    By JGwinn in forum John Deere Ag Tractors
    Last Post: 05-17-2017, 08:54 AM
  2. B21 starts, then stops immediately on key release
    By eepete in forum Kubota Owning/Operating
    Last Post: 05-10-2012, 04:53 PM
  3. John Deere 170 , starts but stops after 30 seconds
    By magnusio in forum John Deere Lawn & Garden
    Last Post: 04-01-2010, 09:36 PM
  4. tc35 starts only 2 to 3 hours after it stops
    By Parfleche in forum New Holland Owning/Operating
    Last Post: 08-22-2009, 10:00 PM
  5. BX2200 Starts, But Stops in "Run" Key Position
    By webhund in forum Kubota Owning/Operating
    Last Post: 06-18-2008, 06:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
