Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Mar 2012
    Posts
    7
    Beaverville, IL
    Ford 4000 1972 3-cyl Gas
    Default 1972 Ford 4000 3-Cyl Gas, Various Problem
    I have 1972 Ford 4000 3-Cyl gas with a cooling problem. I flushed the radiator, which seems to have decent flow (thought it's pretty old and some of the fins are bent). The tractor starts up fine, usually blows one puff of white smoke until it gets going and then the exhaust is clear. After about 600' running my 4' roto-tiller or two bottom plow I start boiling over and loosing coolant. I've replaced the thermostat, radiator cap and radiator hoses.
    Is it worth replacing the radiator and water pump? When I run the tractor without the radiator cap I see slight ripples in the top of the radiator. Does this indicate full flow? How rapidly should the water be moving? Also, so far I haven't seen any bubbles in the coolant. Which I'm hoping is a good sign.
    Also, I have a serious issue with pressure in my gas tank. After about 3-4 hours of running the tractor, pressure builds up in my gas tank and it starts to act like it's out of gas. I replaced the gas cap with a replacement from Napa, which claims to be vented, but there's no difference. Any ideas?
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 1972 Ford 4000 3-Cyl Gas, Various Problem
    is this a cross post? semms like i've read and replied to this somewhere else?
  3. #3
    Gold Member Ultradog MN's Avatar
    Join Date
    Jun 2006
    Posts
    274
    Twin Cities, MN
    Ford 3000, Ford 4450, Ford 4200
    “What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do something about them”
    Henry Ford
  4. #4
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ok, that makes 2 other places I saw it then.
Similar Threads
  1. Yanmar Models
    By Neat 1500 in forum Yanmar
    Last Post: 07-19-2017, 07:53 AM
  2. 3 cyl vs. 2 cyl?
    By Ginormous in forum Yanmar
    Last Post: 04-06-2012, 10:41 PM
  3. Power Steering Problem Not Solved
    By Alan L. in forum Kubota Owning/Operating
    Last Post: 03-31-2011, 07:35 PM
  4. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 11:56 AM
  5. Chain of command
    Last Post: 04-13-2002, 07:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
