Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    May 2012
    Posts
    4
    milaca mn
    1502 ford
    Default 1502 ford drops a cylinder when i blow air on injector pump
    i have a 1502 diesel that seems to run good but does leak diesel from the injector pump, but when i go to blow off the diesel to see where it is leaking from the engine sounds like it drops a cylinder and then usaully dies?? any ideas??
  2. #2
    Gold Member jones6780's Avatar
    Join Date
    Nov 2008
    Posts
    342
    Lizella, Ga.
    Ford 1700 4wheel drive, Yazoo/Kees Max2 Zero Turn
    Default Re: 1502 ford drops a cylinder when i blow air on injector pump
    Is it leaking before the pump? Sucking air, if it is leaking enough by gravity and you remove the fluid it may suck air into the line.
  3. #3
    New Member
    Join Date
    May 2012
    Posts
    4
    milaca mn
    1502 ford
    the fuel is coming out of the injector pump under the "injector" (not sure what they are i call them injectors but they are on the pump) i went to blow the fuel off so i could see where it is coming from and when i hit the front injector the tractor drops a cylinder and then dies..
  4. #4
    Join Date
    Nov 2008
    Posts
    342
    Lizella, Ga.
    OK You have a fuel line going into the pump and a line coming out going to each cylinder and at the end of the line is the injector screwed into the head. From your description it sounds like you are talking about the lines exiting the pump. Leaking there means you are not getting full fuel volume to the injector. I don't see how air can affect the engine at that point. The fuel should have a higher pressure than the air hose. To find the leak clean the pump with soap and water and dry it off. Turn over the engine, to pump fuel, just enough to find the wet spot. Some have used talcum powder to help seeing the leak.
  5. #5
    Join Date
    Mar 2012
    Posts
    236
    Akron, IN
    MF 85 diesel, TO 35 diesel, 165 diesel, IH Hydro 84 diesel, MF Super 90 diesel puller, Agri Power 7000, 8000, and 9000 diesels, MF 205 diesel
    If pump is seeping fuel at delivery valve holders and/or body flange O rings you are getting air into fuel gallery past leaking seals with your blowgun. It will miss or even die depending on how much air gets in. If pump is aluminum body Zexel I may have tools and seals to repair leaks, but need to know what pump you have.
  6. #6
    New Member
    Join Date
    May 2012
    Posts
    4
    milaca mn
    1502 ford
    well tried to fix it but it didnt go so well. had to drop it off at a place that rebuilds these things to get it put back together.. pretty embarassed but at least it will be fixed. the guy figured it was one of the brass rings that are leaking. i was looking for the two rubber o-rings on the bottom but they didnt put them in until 90 and mine is an 88, shold have read the parts schematic a little better i guess!! oh well that is a lesson learned i guess.. thanks for the replies though this is just way over my head!
Similar Threads
  1. Ford 3910 3-point drops on its own
    By BBlocker in forum Hydraulics
    Last Post: 06-03-2008, 02:54 PM
  2. Ford 1520 3-pt lift problem- drops down then jerks back up
    By NathanatFork in forum Parts/Repairs
    Last Post: 02-22-2008, 05:10 PM
  3. B7510 Top N Tilt-Tilt cylinder too long
    By btolle in forum Kubota Owning/Operating
    Last Post: 04-05-2005, 03:36 AM
  4. Updated cylinder count
    By RobertN in forum Related Topics
    Last Post: 08-05-2004, 06:49 PM
  5. Hydraulic Question
    By butzkeg in forum John Deere Owning/Operating
    Last Post: 12-11-2001, 07:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
