Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    May 2012
    Posts
    3
    hobart, OK
    John Deere Massey
    Default 617 disc mower
    Hope I am in the right place to post a question. My first time in.
    I have a 617 disc mower that I need to replace the belt. I am having difficulty in discovering where or how to adjust the belt tension. Obviously I need to release the tension on the belt to remove it and replace with a new one.
    Any words of wisdom would be appreciate. Thanks.
  2. #2
    Veteran Member whodat526's Avatar
    Join Date
    Apr 2010
    Posts
    1,529
    deridder louisiana
    fords
    Default Re: 617 disc mower
    Quote Originally Posted by tubby3 View Post
    There is a eyebolt and a big spring and nut that is connected on the big pully it is right on the other side of the belt covers right near where the pto shaft hooks to the cutter
  3. #3
    New Member
    Join Date
    May 2012
    Posts
    3
    hobart, OK
    John Deere Massey
    Thanks. I tried to loosen that but no luck. Maybe I need to try to move the "ear" that the bolt is hooked to or make sure the mower is resting on the ground level. Thanks again.
  4. #4
    Advertiser sweettractors's Avatar
    Join Date
    Jul 2003
    Posts
    7,645
    Central Kentucky
    JD 6403 CHA-JD 3130 CHA
    You usually get some slack there and then probably walk the belts off and on the pullys 1 at a time. Ken Sweet
    http://www.sweetfarms.com/
    Sweet Farm Equipment LLC (Internet Sales, Shipping All States)
    Shipping Facility
    1815 Defries Rd., Canmer, Ky 42722 Toll Free 1-866-528-3323
    Ken Sweet sweet@scrtc.com
    Shipping Example: Can ship 800 lbs from Ky. to Dallas for $165
    The Northeast shipping corridor is a little more expensive.
  5. #5
    New Member
    Join Date
    May 2012
    Posts
    3
    hobart, OK
    John Deere Massey
    That's what I did not do. Thanks. I'll try that tomorrow.
  6. #6
    Join Date
    Apr 2010
    Posts
    1,529
    deridder louisiana
    fords
    it should be a power beilt on yhat cutter not four seperate belts
    but yea try and move the ear the tie bolt is connected to if it wont move you need to free it up because on my 616 if the nut is backed off to the end of the threads the belt just falls on and off
Similar Threads
  1. To Flail or not to Flail
    By EastTexFrank in forum Attachments
    Last Post: 05-24-2011, 04:07 AM
  2. Opinion on NH 617 Disc Mower
    By rxk9394 in forum Attachments
    Last Post: 03-02-2011, 11:54 PM
  3. Vicon CM2200 Disc mower breaks in half!!
    By smgriffin in forum Ag Tractors & Machinery
    Last Post: 11-15-2010, 05:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
