Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Sep 2002
    Texas - Ellis County
    Default TC-40D HST PTO Hard to engage
    My PTO has become harder and harder to engage/disengage. I have cleaned the linkage with no better results. Is the problem internal? Any ideas? Thanks.
  2. #2
    Join Date
    Apr 2012
    Default Re: TC-40D HST PTO Hard to engage
    Your problem is most like likely the plastic bushings and shaft that the pto lever is mounted to. When the shaft rusts the plastic bushing will bind.
    You can determine if the shaft and bushing are binding by wiggling the pto lever side to side. By comparing the play with another lever you will see there is a certain amount of play
  3. #3
    Epic Contributor
    jinman's Avatar
    Join Date
    Feb 2001
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Steve, Mike (Spicer) is correct. All the levers on the left side pivot on the same shaft. Looking at the illustration below, that pivot shaft is item #14. When I took mine apart, the shaft was corroded. Cleaning that up and adding a little lube should take care of your problem. To get at the shaft, you'll need to remove the left side plastic console. It's bolted on from underneath the fender and you can even get to the bolts without removing the wheel. With the console off you can unbolt one bolt on each end of the shaft and slide it out so it can be cleaned. That's what I'd suggest as a first step and probably will be all you need.
    Attached Thumbnails Attached Thumbnails TC-40D HST PTO Hard to engage-tc45-leftlevers-jpg
Similar Threads
  1. JD F935 - PTO won't engage
    By CentralNC in forum John Deere Lawn & Garden
    Last Post: 08-08-2014, 12:17 AM
  2. '72 2000 PTO shift lever grinding to engage (tricks - best way) ???
    By schiker in forum New Holland Owning/Operating
    Last Post: 12-05-2011, 09:10 AM
  3. JD 4600 HST PTO Problem
    By kabeman in forum John Deere Owning/Operating
    Last Post: 07-22-2008, 12:09 PM
  4. 1540 rear PTO lever wont engage
    By coolhl7 in forum Massey Ferguson Owning/Operating
    Last Post: 02-19-2007, 06:24 PM
  5. TC 40D PTO Generator - Disappointing
    By djradz in forum New Holland Owning/Operating
    Last Post: 01-27-2007, 10:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
