sparc
- Joined
- Oct 2, 2011
- Messages
- 1,093
- Location
- NJ
- Tractor
- JD 4410, NH TC-25, Bobcat M610, JD X534, Dig-It Model 158, JD Ztrak 737. 6X4 Gator
I was looking the motor and noticed that the vacuum advance line to the distributor was loose. I tried to tighten the nut , but it was tight . however the tubing was loose and rotates inside the nut, and can not be tightened anymore . I loosened the nut and removed the fitting . I found that there is no flare on the end of the tubing and I think there should be .
so what is the proper configuration ?
