Results 1 to 6 of 6
  1. #1
    Member Shepp's Avatar
    Join Date
    Aug 2012
    Posts
    42
    Toronto Ontario
    Ford 3000
    Default Pilot Bearing And Release Bearing On A Ford 3000
    OK so I managed to split my Ford 3000 and the new clutch package came the other day. I was looking at the Pilot bearing on the tractor and it looks like I have to remove the fly wheel to replace the pilot bearing. Is this correct?
    I was also looking at the release bearing. I thought there should be some kind of retaining clip to hold it in place, but it doesn't appear to have one. My IT shop manual doesn't really explain how to remove it. Can someone explain this to me. Any help would be greatly appreciated.
    Shepp
  2. #2
    Veteran Member whodat526's Avatar
    Join Date
    Apr 2010
    Posts
    1,510
    deridder louisiana
    fords
    Default Re: Pilot Bearing And Release Bearing On A Ford 3000
    The pilot bearing just pulls out with no need of removing the flywheel and the throw out bearing u just need to knock it off the housing nothing holds it in place it just drives on
  3. #3
    Join Date
    Aug 2012
    Posts
    42
    Toronto Ontario
    Ford 3000
    OK thanks Whodat526. Not a lot of room there to knock it off with a hammer. I might be able to borrow a bearing puller.
    Shepp
  4. #4
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,482
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    I learned a trick years ago in removing a pilot bushing. Find a rod that just slides into the bushing. Pack the bushing with thick grease and then put then push the rod into the bushing and hit it with a hammer. You will push the bushing out with hydraulic pressure from the grease. It has worked for me without fail.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  5. #5
    Join Date
    Aug 2012
    Posts
    42
    Toronto Ontario
    Ford 3000
    Thanks Dex3361. Yes I have seen this method performed on youtube.
    Shepp
  6. #6
    Join Date
    Aug 2012
    Posts
    42
    Toronto Ontario
    Ford 3000
    Well I didn't need to remove the flywheel to get the pilot bearing out, but I had to remove the flywheel bolts and pilot bearing retainer plate to remove the pilot bearing. The throwout bearing was hard to remove. I finally used a steel drift pin through the steering box opening above the bearing. Several good hits with a hammer and she came off. I am still waiting for a clutch alignment tool to come in the mail. Hopefully next weekend I will put the new clutch in.
    Shepp
Similar Threads
  1. clutch and pilot bearing repair ?
    By p650gnewt in forum Mitsubishi/Satoh
    Last Post: 12-14-2011, 09:02 AM
  2. Kabota B6100 release bearing
    By IntrepidPD in forum Kubota Owning/Operating
    Last Post: 11-14-2011, 06:19 AM
  3. sealed bearing are grey iron bearing disc harrow
    By little kubota in forum Attachments
    Last Post: 07-22-2010, 09:08 AM
  4. 95' 1715 input shaft pilot bearing clearance
    By fishjett in forum New Holland Owning/Operating
    Last Post: 09-15-2008, 01:51 AM
  5. Throw out bearing release collar stuck
    By Drewyzr1 in forum New Holland Owning/Operating
    Last Post: 04-12-2007, 03:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
