Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    May 2009
    Posts
    7
    MA
    TC45D
    Default Four Wheel Drive Problem....noises!
    My 06 TC45D recently started like a rotational /grinding noise only in 4WD. It "popped" under load straight line.Sounds like it was wearing/weakening/breaking prior to when it actually failed,but it gave no indication. I have not used the 4WD since . It only happened once.
    I am pretty sure after isolating the problem somewhat (adjusted linkage to make sure I was fully engaged;lifting all 4 wheels off ground and placing it in 4WD) that the noise is coming from where the front shaft engages the differential; the spline area. Under no load while lifted I can feel the shaft catching as it rotates, it should be rotating completely free of course.
    I did some forum searching and located a couple threads and blow up diagrams.I am trying to refine my next action and what I am up against. If its something I should disassemble and what parts, how long,how much,etc..What anyone knows about this issue is welcome information.
    Thanks,
    Paul
  2. #2
    Veteran Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    1,457
    Ararat Vic Aus
    Default Re: Four Wheel Drive Problem....noises!
    G'day first thing I would be doing is to drain the front diff oil into a nice clean container and look for metal ( shavings or chunks) if you do find any then I would be pulling the front diff to bits to find out what has failed. The problem with this type of fwd is that even though you have got the 4wd disengaged it will still turn the front diff and final drives ( i.e no free wheeling hubs) so if you have got damage in the diff then you are prob making it worse by still using the tractor.
    If you have a sliding coupling where the driveshaft from the trans to the diff goes into the diff then slide it back and check the splines on it as they have been known to wear there as well.
    Let us know what you find and good luck
    Oh and to TBN
    Jon
  3. #3
    Join Date
    Apr 2012
    Posts
    138
    WI
    Case
    If your tractor is equipped with Super Steer you should inspect the yokes threaded pins. These pins retain the yokes onto the splines. The threaded pin is threaded into the yoke while the pinned end extends into a bore on the splined shaft. This pin was missing and had to be replaced on my TC40D.
    If this threaded pin is missing from the yoke you could damage either the yoke shown below or the splined coupling in the drop box. The damage would occur when these respective components travel off the splines.
    Mike
    Four Wheel Drive Problem....noises!-yoke-jpg
  4. #4
    New Member
    Join Date
    May 2009
    Posts
    7
    MA
    TC45D
    Thanks for the replies.
    It is not a super steer.
    Any opinions on this being a job I should attempt repairs on?
    Or even remove parts and take an assembly to a differential repair shop?
    Thanks
    Paul
  5. #5
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Quote Originally Posted by pkirby View Post
    Thanks
    Paul
    Paul, I think you have to answer those questions best for yourself. Do you have a repair manual with all the specs for runout and preloading? Do you have any experience working on differentials? If you do this and it breaks again or you can't get it back together safely, can you afford to pay somebody else after spending the money on repair parts for your first attempt?
    My calculations of whether I want to do a job always include whether I can afford to pay somebody else to fix my mess. For many things, that convinces me to just let them do it from the get-go. Of course, I have great confidence in my dealer's shop and have a good relationship with them. I also know my own limitations. These are all things that you have to consider for yourself.
    So, I guess I rambled around and didn't answer your question. I would say yes. . . maybe.
    Jim
  6. #6
    New Member
    Join Date
    May 2009
    Posts
    7
    MA
    TC45D
    All opinions welcome,so thanks. As you can imagine I am weighing those same concerns . Haven't done anything yet but will advise my course of action . Any other thoughts on my situation I would like to hear.
    Thanks,
    Paul
  7. #7
    Gold Member jones6780's Avatar
    Join Date
    Nov 2008
    Posts
    343
    Lizella, Ga.
    Ford 1700 4wheel drive, Yazoo/Kees Max2 Zero Turn
    Like Jinman said only you can decide. I would do the disassemble and inspection, then based on what the problem is make a decision on who fixes it. The repair shop doesn't need the whole tractor just the broken parts or sub assembly, provided you can reassemble.
  8. #8
    New Member
    Join Date
    May 2009
    Posts
    7
    MA
    TC45D
    I opted for professional repair. I will stick to what I am good at (when I find out what that is).
    So far it is the "coupling" that has failed.
    It is part #39 on the diagram. It has been superceded by #39.1. Does anyone know why?
    Additionally ,the drive pinion is maybe a problem. It is over $500. The drive pinion also has been superceded with a new part .
    Will know more tomorrow.
    Paul.
  9. #9
    Join Date
    Jun 2012
    Posts
    938
    East Tennessee
    John Deere 4200 w/backhoe, Ford 3000,580 Case backhoe
    Good luck.
  10. #10
    New Member
    Join Date
    May 2009
    Posts
    7
    MA
    TC45D
    I ordered a new drive shaft,ring and pinion gear,and coupling My front axle number (take left front tire off; stamped in hub) number was high enough that I didn't have to order the updated casing for an additional $603. As it is, I have over $800 in parts coming in. The ring and pinion was over $500 by itself..
    Will update end of week after repairs are hopefully completed.
    Paul
Similar Threads
  1. front wheel drive problem
    By maddog69 in forum Kubota Owning/Operating
    Last Post: 11-13-2012, 06:49 PM
  2. Fixed my little 4 wheel drive problem...
    By Tractor Factor in forum Kubota Owning/Operating
    Last Post: 05-14-2010, 08:09 PM
  3. Four Wheel Drive problem
    By ctjstr in forum New Holland Owning/Operating
    Last Post: 07-08-2008, 10:01 AM
  4. DK45S 4 wheel drive problem
    By fastpat in forum Kioti Owning/Operating
    Last Post: 03-14-2007, 11:40 AM
  5. B2710 4 Wheel Drive Bearing problem?
    By oldmansfarm in forum Kubota Owning/Operating
    Last Post: 09-21-2005, 09:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
