Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Jun 2011
    Posts
    6
    Cavendish, Vermont
    New Holland 2120 TLB,Ford 1985 2110/Loader, John Deere 755/Front Mounted Snow Blower,International 500E Crawler/4n1Bucket
    Default Single lever loader control
    Trying to install a single lever loader control in place of the 2 lever on my 2110 Ford. It is a NOS for a 2120 Ford around 1988. It is a Zexel stamped 46224 on the ID tag, which states Assn. No 307800-0721, Assn. Code 34001-3541. I don't know if it needs or I should say they use a power beyond bushing in the power beyond connection, which I believe is the one farthest away from the operators position. The center connection I think is the inlet, with the return being closest to the operator. Any info will appreciated.
  2. #2
    Join Date
    Sep 2011
    Posts
    2,385
    vermont
    Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200
    Default Re: Single lever loader control
    Ron
    Running on part numbers takes specific knowledge. You could gain the universal knowledge of this very knowledgeable group with just a photo. (or two.
    Sometimes, the external appearance of a valve gives a clue as to what is going on inside.
    Take out any port plugs and have a look. PB bushings have "features" that may help in identification.
    Cheer
    Cal
    in Guilford VT.
  3. #3
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Wow I can find nothing on the web using Zexel with the numbers you have given. There are many different search results for Zexel and for Zexel hydraulics but nothing that is helpfull. Is there any other information numbers or names on the unit?
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  4. #4
    New Member
    Join Date
    Jun 2011
    Posts
    6
    Cavendish, Vermont
    Back from Fryeburg Fair and have caught up on chores. When I hooked up the controller like I thought it should be connected the Up,Down and Float function worked properly, but when I dumped the bucket it went all the way, then could never get it back or to curl. I took some pictures included are the pictures. Single lever loader control-101_0964-jpg Single lever loader control-101_0964-jpgSingle lever loader control-101_0964-jpg I hope this worked, there should be three pictures.
  5. #5
    New Member
    Join Date
    Jun 2011
    Posts
    6
    Cavendish, Vermont
    It didn't work. Another picture.Single lever loader control-101_0962-jpg I'll try one at a time. One more try.Single lever loader control-101_0961-jpg
  6. #6
    Silver Member nsmithnd's Avatar
    Join Date
    Feb 2011
    Posts
    102
    Bismarck, ND
    Ford 1700
    Would this be it? Ford/NH 1220
    Expand the Hydraulic Systems folder and about half-way down is a couple of references to 2-Spool Remote...
    And here is another thread that might have all the info you need... (click here)
    -Neil
Similar Threads
  1. Single lever loader control
    By ronbrent in forum Hydraulics
    Last Post: 09-30-2012, 12:45 PM
  2. DK loader control lever
    By ddb123 in forum Kioti Buying/Pricing
    Last Post: 05-08-2012, 05:08 PM
  3. ford tractor single lever loader controls
    By ronbrent in forum Ford
    Last Post: 06-17-2011, 08:23 PM
  4. How to grease loader control lever linkage
    By rmg in forum Kubota Owning/Operating
    Last Post: 05-06-2008, 02:58 AM
  5. Loader - lubricate the joints of the control lever?
    By MDM in forum Kubota Owning/Operating
    Last Post: 05-06-2007, 03:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
