Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    New Member
    Join Date
    Oct 2012
    Posts
    8
    Default
    Super! One last question, I hope. I assume the major flange on the new seal faces the ball bushing and thus the fluid side of the housing.
  2. #12
    Join Date
    Jan 2012
    Posts
    139
    California
    Ford 7710, Ford 550, Ford 1910, Ford 4430, KD Forklift, Ford LGT17H, New Holland L255 Skidsteer
    Default Re: Leaking Seal on TN55
    The flange or lip of the seal always faces the oil.
  3. #13
    New Member
    Join Date
    May 2009
    Posts
    20
    North Ga , NE Al
    2003 New Holland TN65 4wd
    I am doing this same repair and am having trouble getting the bushing out with a socket a bit smaller than the bore. I did remove the spring clip successfully. THe socket destroyed the old seal but that is ok .... the bearing seems pressed in and tapping harshly on the socket wont budge the bushing. Can you elaborate on how hard to hit the socket and how to be sure the socket is pushing on the lip of the bushing and not damaging the swivel portion? Many thanks
  4. #14
    Join Date
    Jan 2012
    Posts
    139
    California
    Make sure you soak it in penetrating oil. You have to rap on it fairly hard, but you MAY damage the bushing if it is frozen, but it should budge with some penetrating oil soaked into it. Make sure you are wearing safety glasses, too.
  5. #15
    New Member
    Join Date
    Oct 2012
    Posts
    8
    Default
    Seals replaced and everything reassembled, loaded up with new tractor oil and good to go. Already put a couple of hours in mowing. No leaks. Many thanks to Tractor Tech.
  6. #16
    Join Date
    Jan 2012
    Posts
    139
    California
    Default
    Quote Originally Posted by Bandit457
    I haven't done any for awhile, but just had one start leaking. 2004 TN95FA w/6000 hrs. Very rusty. The bushing on the outside and the lower link rusted severely. After several hours and no torch to break it loose, they are both replaced. Attached is a picture of the side that was rusted.
    Sometimes it's easy, sometimes it's not!
Similar Threads
  1. Leaking seal on BX2200?
    By AaronS in forum Kubota Owning/Operating
    Last Post: 09-13-2011, 09:34 PM
  2. Leaking seal on 5740
    By nebraskasparks in forum Kubota Owning/Operating
    Last Post: 02-18-2011, 08:58 AM
  3. Leaking Seal
    By PWGflyboy in forum Yanmar
    Last Post: 08-31-2006, 04:50 PM
  4. Leaking Wheel Seal
    By TORQUIN in forum Kubota Owning/Operating
    Last Post: 07-09-2006, 05:05 PM
  5. Leaking seal
    By Michael_S in forum Kubota Owning/Operating
    Last Post: 06-22-2003, 09:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
