Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    7
    Ashford, CT
    Ford 2000 TLB
    Default 1975 Ford 2000 Hydraulics Bleeding
    Can anyone help with bleeding instructions for Ford 2000 ? I had a hose go on the backhoe, refilled the fluid, and i apparently have a lot of air in the system because the loader now is having trouble. I have read 2 different opinions
    1) No bleeding necessary because the air escapes out of the pump just use the hydraulics.
    2) un screw the hard line going into the hyd pump and attach a hose to it back to the fill tank and run until smooth
    99FordStang
  2. #2
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,138
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 1975 Ford 2000 Hydraulics Bleeding
    keep the sump full and just run all the cyls lock to lock several times and it WILL self bleed ...
Similar Threads
  1. Hydraulics on 1975 Ford 5000
    By BWMJ in forum Hydraulics
    Last Post: 08-21-2012, 09:17 AM
  2. 1975 Ford 2000 Hyd Questions
    By EWJ in forum New Holland Owning/Operating
    Last Post: 03-02-2012, 08:59 PM
  3. Oil & Fuel 1975 Ford 2000 diesel dipstick
    By fishfighter in forum New Holland Owning/Operating
    Last Post: 04-18-2009, 12:33 PM
  4. Oil & Fuel Amount of oils in a 1975 Ford 2000 Diesel
    Last Post: 03-21-2009, 06:59 AM
  5. Oil dip stick for a 1975 Ford 2000?
    By fishfighter in forum Parts/Repairs
    Last Post: 03-11-2009, 06:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
