iamwallybee
I have a 1310 tractor with 770a or maybe b loader. My question is where is the hydraulic screen located. My manual says on the left side of transmission. Weel if it is there it is invisable. It does have a canister up by the pump (on the right side of the motor) supply line goes to this canister then to the pump. Is this the filter/ screen? It has gotten water in the system and want to make sure screen is clean before I put the fresh oil in it. I have put good used hyd oil in it 2 times to help clean up the water problem, now bucket works but very slow and doesnt pick up as much weight. If not clogged filter then what to look for? Bucket worked just ok before I started. Thanks.
