Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 46
  1. #11
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Default Re: No hydraulics... GAH!!!
    Time for a torpedo heater. I would NOT light a fire under the tractor, but a torpedo heater will heat things up really fast, especially if you block the far side of the tractor with a full or partial sheet of plywood so that the air/heat doesn't just escape. These things say they are to be run on kerosene, but outside, I run mine with diesel.
    No hydraulics... GAH!!!-heater951-jpg
    Jim
  2. #12
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Quote Originally Posted by jinman View Post
    Jim, Are you taking the chill out of that 40* Texas air? Those torpedo heaters do throw some heat. The local TSC had a bunch of them in-stock last time I was in there.
  3. #13
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,418
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    I would not run the tractor for long w/o hyd because oil is not going thru the pump as it should. I would have built a charcoal fire and warmed the underbelly to melt the plug.
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  4. #14
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Quote Originally Posted by dave1949 View Post
    Dave, the last time I used mine, I was installing a rear bumper on my Dodge truck. It was about 35 degrees out and that warm torpedo heater sure felt good blowin' warm air up my. . . uh. . .shirt. Yeah, that's the ticket.
    Jim
  5. #15
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Quote Originally Posted by SPYDERLK View Post
    Larry, I thought about the time I started my tractor when it was about 20 degrees out. I ran out and started the tractor and immediately went back inside to wait for it to warm up without ever checking the hydraulics for operation. When I first read this thread, I identified with Marveltone's doing exactly that. I don't operate my tractor enough in cold weather to ever think of that without reading a thread like this one.
    Jim
  6. #16
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    I think Joe froze to his tractor , hope he got it going.
  7. #17
    Veteran Member Marveltone's Avatar
    Join Date
    Jun 2010
    Posts
    1,491
    Somewhere north of Roseau, MN
    Fordson Major Diesel, McCormick Deering W4, Ford 1510, John Deere L111
    I'll let you know tomorrow eve. We've been busy the last couple days, but I took tomorrow off, as it will be in the 20's for one last day before it gets cold again.
    I went to the house in town and got our 55,000 BTU Reddy Heater. I'll put some scrap plywood sheets around the tractor and perhaps a couple tarps over the top to trap the heat, ignite the heater and let 'er cook! After a couple hours (or when everything feels warm to the touch), I'll loosen the drain plug to see if any water comes out. If so, I'll drain until hydraulic fluid appears. If no water comes out, I'll just fire up the tractor and see what happens.
    Joe
    Joe
    Fordson Major Diesel: Case 3-bottom Trip Plow, Case 12' Trip Field Cultivator, Kewanee 130 Disc, John Deere 1209 Mower Conditioner, John Deere 594LW Side Delivery Rake, New Holland Hayliner 273 Baler, 18' Spike-Tooth Harrow
    Ford 1510: Du-Al 105 Loader, "The Thumb" Grapple, Bush Hog RBC60 Rear Blade, Woods HC54 Rotary Cutter, Tarter 5' Heavy-Duty Hinge Back Box Blade, Buhler Farm King Y600 Snowblower
  8. #18
    Elite Member
    Join Date
    Dec 2000
    Posts
    2,968
    Southern VT, Southern ME
    John Deere 4100 HST /410 FEL, R4s
    What no hot dogs?
  9. #19
    Join Date
    Jun 2010
    Posts
    1,491
    Quote Originally Posted by DFB View Post
    What no hot dogs?
    Rats! I knew I forgot something from town. Oh well... S'mores will have to do.
    Now where did the wife hide the marshmallows?
    Joe
    Joe
  10. #20
    Join Date
    Jun 2010
    Posts
    1,491
    20 degrees today, so I put the Reddy Heater between the tractor and snow blower, put a couple sheets of OSB on the sides and covered the top with a cheap tarp. I then plugged in the heater, did some chores and went in for lunch. About three hours later, I crawled under the tractor, cracked the drain plugs to see if there was any sufficient amount of water to drain out. One plug netted about 1/2 teaspoon of clear water. Nothing else but Hydro fluid in the rest. By this time everything on the tractor was warm to the touch. I figured it was time to fire it up and pray.
    No hydraulics... GAH!!!-0129131200-jpgNo hydraulics... GAH!!!-0129131200a-jpgNo hydraulics... GAH!!!-0129131200b-jpg
    SUCCESS!
    I finished up all my snow removal projects that had been abbreviated a couple days ago, plus opening up new roads to other wood piles. It's good to be back!
    Now my next question is this: I see on Sea Foam's website they say we can put their Trans Tune in hydraulic systems to help with water and ice problems. Anyone have any experience/opinions on this?
    Joe
    Joe
Similar Threads
  1. Gah! Dead battery. C'mon, paycheck!
    By Marveltone in forum Owning/Operating
    Last Post: 05-05-2011, 10:02 PM
  2. to-30 hydraulics
    By farminfool in forum Hydraulics
    Last Post: 10-06-2009, 04:56 AM
  3. Hydraulics
    By donethat in forum Customization
    Last Post: 04-06-2006, 09:49 AM
  4. Remote Hydraulics: Impact On Overall Hydraulics?
    By Ursushorribilus in forum Attachments
    Last Post: 10-14-2004, 04:44 PM
  5. GAH!!!! I bent the 'foot' on my 7308 loader...
    By KrisHansen in forum New Holland Owning/Operating
    Last Post: 04-19-2004, 03:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
