OP
OldBulldogger
Apparently the quick coupler must have released but initially the hose did not pop out of the coupler fullu to notice it but just enough to close the ball check and block the line which caused my problems. When I wiggled the hose in the inlet port, it I must have pushed it far in enough to let oil past the ball check to where I noticed the leaking. (It had never leaked before in 3 years of ownership and I have never had it out of the coupler) Once I reconnected the hose in the quick coupler, I wiped it clean with a shop rag. After reconnecting, I had restored full power to everything. Again why it released just now to cause my problem is a mystery but like I said, last fall I was doing quite a bit of brush clean up and a stick must have bumped it loose. Otherwise I can't explain why it would be loose.
I am just thrilled that is all it was! :thumbsup: Thanks for ALL your help JC, you taught me quite a bit on how to troubleshoot it again in the future.
