Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    New Member vdubdezl's Avatar
    Join Date
    Feb 2013
    Posts
    11
    alcolu, sc
    ford 4600SU
    Default Re: TC29D Hydrostatic transmission is stuck in forward
    Has anyone done this before? I don't see an access hole other than this one I had to jam my phone into to take the pic. I was thinking about pulling it up with a coat hanger so I can thread it back in. We are going to order the whole rod and both rod ends to replace because I am assuming it has vibrated the threads out.
  2. #12
    Super Star Member jinman's Avatar
    Join Date
    Feb 2001
    Posts
    18,724
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Quote Originally Posted by vdubdezl View Post
    Thanks for the pic Ruffdog. The rod for the valve in the transmission fell off as you can hopefully see. Also thanks to you Jinman for the detailed pic which is what I was looking at. I flat did not see the rod on the back side of the arm. As you will notice it isn't in the pic! It goes on near 13 and 12, but isn't clear. THANKS AGAIN!! Attachment 305984
    Your picture seems to be the slot where the rod goes inside the transmission and screws into the swivel that controls the transmission swashplate. You'll have to be very careful to get that all back together. It looks like it is a threaded rod with a locknut. The locknut probably loosened and allowed the joint to unscrew. Just a guess. At least you know where the problem is and that's 50% of getting it fixed. You might ask your dealer's service manager if there are any tips. My service manager and techs at my dealer are always generous with their good advice.
    Jim
  3. #13
    Join Date
    Feb 2013
    Posts
    11
    alcolu, sc
    ford 4600SU
    Quote Originally Posted by jinman View Post
    Yes, definitely knowing the problem is the half of it. I don't know any one at either of our 2 nearest local dealers. I used to know a few of the parts guys at both places from me using them when I worked at my dad's diesel shop. Some dealers are great, and some aren't. I sent my co-worker(with the John deere) to nearest dealer in the next town from me to speak to the service manager, who happens to know me and lives 2 houses down from me(over 1/2 mile here in the country). He was completely rude and offered no help and barked at one of the mechanics for talking to him. So when he needed over $2000 worth of parts, he went in the other direction to the next nearest dealer and they helped him.
  4. #14
    Join Date
    Dec 2011
    Posts
    198
    South central Wisconsin
    New Holland TC33D w/supersteer and loader
    I am wondering if the nut came loose and the movement back and forth wore out the threads.??? Yes, that would mean much more work. If all you needed to do was to screw it back together and tighten the nut, you could use a metric crows foot for that. I think I will look at my tractor tomarrow and check that nut for tightness.
    NH TC33D, 6ft Behlen cutter, Lorenz blower, KK tiller, Kubota RTV900, Stihl 026, 029, 361, 460, Speeco splitter, Cub Cadet 982
  5. #15
    Join Date
    Feb 2013
    Posts
    11
    alcolu, sc
    ford 4600SU
    I am going to try and thread it back in just to see how bad it is. I have a set of metric crow's foot so that shouldn't be a problem.
  6. #16
    Join Date
    Dec 2011
    Posts
    198
    You might want to loop a piece of duct tape from the extension, around the crows foot, back to the extension, just in case. You don't want to drop it while you pull the tool out.
  7. #17
    Join Date
    Feb 2013
    Posts
    11
    alcolu, sc
    ford 4600SU
    Threaded it back in and got it back working. I believe you would have to split the tractor to get in there to replace. really dumb design with no access panels!!
  8. #18
    Join Date
    Feb 2001
    Posts
    18,724
    Glad for the success report. Did you use any new parts or just put the old ones back together? Red Loctite on the threads?
    Jim
  9. #19
    Join Date
    Feb 2013
    Posts
    11
    alcolu, sc
    ford 4600SU
    No jinman. no new parts. Threaded the old one back on and tightened both nuts. Loctite would have been a great idea....if I thought of it!!
  10. #20
    Join Date
    Dec 2011
    Posts
    198
    Was the top nut also loose to allow the rod to turn? That is not an easy location to work on for sure!
Similar Threads
  1. Stuck in forward
    By jimmyv in forum Parts/Repairs
    Last Post: 07-28-2012, 04:14 PM
  2. forward pedal stuck
    By Gary Beaulieu in forum John Deere Owning/Operating
    Last Post: 01-20-2012, 09:05 AM
  3. Hydrostatic not working TC29D New Holland
    By dletourneau3 in forum Hydraulics
    Last Post: 09-23-2011, 09:36 AM
  4. bx24 forward pedal stuck?
    By ericecon in forum Kubota Owning/Operating
    Last Post: 05-22-2009, 08:37 AM
  5. 110 tlb hydrostatic surge in forward
    By kellytheaker in forum John Deere Owning/Operating
    Last Post: 08-28-2006, 06:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
