vdubdezl
TC29D Hydrostatic transmission is stuck in forward. It will shift in and out of gear on the gear stick, but when you press the hydrostatic pedal it will only go forward when let up on the "clutch" pedal. I have checked the linkage on the pedal and it is not bent. I removed the covers and checked the reostat that the hydro pedal connects to and I am reading resistance. The resistance will go up and down depending on where you press the pedal. Where is the control valve or solenoid located so I can check it? Any other ideas?
