Results 1 to 4 of 4
  1. #1
    Member
    Join Date
    Aug 2012
    Posts
    45
    Chesapeake, VA
    Ford
    Default 2000 series tractor carberator loading
    I have a 73 Ford 2000 series tractor 3 cyl gas and it has been very well maintained. I replaced the carberator because it had some leaks and it was about 15 yrs old. The old carberator seemed to load when idleing. After replacing it, the new carb. seems to be doing the same thing. It starts quick and runs very well. When idleing, it purrs yet, it still seems to load. It will idle and every minute or so it will idle up a little and every once in a while it back fires or pops. I have not messed with the jets and have tried to find posts relating to this problem. Does anyone have any suggestions?
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 2000 series tractor carberator loading
    popcorn sound scan be lean. a 'hunting throttle' can also indicate a lean situation.. the engine starts to stall, governor snatches throttle open, increased manifold vacume sucks more fuel thru.. she overrevs.. throttle goes slack from governor, and she dies back down.
    I'd check fuel delivery first.
    read the plugs too.
    if plugs are black and sooty.. yet she acts lean.. check for vacume leaks.. likemanifold / carb gaskets..e tc..e tc.
  3. #3
    Member
    Join Date
    Aug 2012
    Posts
    45
    Chesapeake, VA
    Ford
    Thanks Soundguy, as usual you are right on time again. The vacuum advance vacuum line was the culprit. When I went to check it, I started backing the fitting out and the line was about 50% broke. I got a new piece of line and put it back together. I started the tractor and with a lil distributor adjustment it was purring like a kitten. I bushhogged and tilled a couple of acres and it ran like a top. Thanks again, Howie
  4. #4
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    glad you got her fixed...
Similar Threads
  1. Replies: 1
    Last Post: 08-19-2012, 10:49 PM
  2. Carberator
    By George49 in forum Parts/Repairs
    Last Post: 07-12-2012, 07:06 PM
  3. kohler magnum8 carberator
    By skylab in forum Rototillers
    Last Post: 07-05-2011, 09:27 PM
  4. 2000 Series Compact Utility Tractor
    By mhalla in forum John Deere Buying/Pricing
    Last Post: 03-18-2003, 08:49 AM
  5. Loading a B-series on a pick-up
    By BigC in forum Kubota Buying/Pricing
    Last Post: 07-23-2000, 12:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
