Results 1 to 9 of 9
  1. #1
    New Member Rollincoal's Avatar
    Join Date
    May 2012
    Posts
    8
    Ok
    2012 4520 I'd
    Default Tz22da
    I just purchased a tz22da with 60cms mid mount mower. With a tiller on the back the mower deck won't lower all the eat to ground? Do I need to take off the rear implement to get it to lower?
  2. #2
    Bronze Member mkow1969's Avatar
    Join Date
    Dec 2011
    Posts
    60
    Newfane, NY
    New Holland T1110
    Default Re: Tz22da
    Yes, you will need to take off the tiller to get the deck to go all the way down to the ground. Problem is there is a bar that goes from the rear lift mechanism that contols the deck lift. You can see it if you are looking at the rear of the tractor on the left upper arm that lifts the left part of the 3 pt hitch. The rototiller doesnt't allow the am to drop all the way so your deck stays up in the air a bit.
    Just a heads up... I changed out the oil in the gear box on the deck and put in some Lucas 80 - 90 wt gear lube. Seems to run quieter. Super easy and cheap maintenance.
  3. #3
    Join Date
    May 2012
    Posts
    8
    Ok
    2012 4520 I'd
    Default
    Thanks, I have a mystery part also I need identified ill put a pic up soon.
  4. #4
    Join Date
    Dec 2011
    Posts
    60
    Newfane, NY
    New Holland T1110
    Default Re: Tz22da
    cool. i had a tz18DA, a T1010 and recently traded it in for a T1110. Hope I can help. Marty
    I really like the tractors. Had a few goofy issues but no complaints so far.
  5. #5
    Join Date
    May 2012
    Posts
    8
    Ok
    2012 4520 I'd
    Default
    This is the mystery part????
    Tz22da-image-2503845907-jpg
  6. #6
    Join Date
    May 2012
    Posts
    8
    Ok
    2012 4520 I'd
    Default
    What kind of goofy issues?
  7. #7
    Join Date
    Dec 2011
    Posts
    60
    Newfane, NY
    New Holland T1110
    Default Re: Tz22da
    Not sure what that is. I'll look around a parts diagram. Was this just handed to you or did it fall off the tractor?
    I had to adjust that bar that lifts the deck every couple months. No biggie. It was just removing the cotter pin and turning the end a few times to shorten it. Also had some cracks in the metal deck under the seat. NH has a kit that took care of that. It was where the seat mounted to the metal decking.
    Nothing major. I loved the tractor.
  8. #8
    Join Date
    May 2012
    Posts
    8
    Ok
    2012 4520 I'd
    Default
    It was in the operators manual ring binder hole. I've looked some but can't figure it out. Thank you for your help.
  9. #9
    Join Date
    Dec 2011
    Posts
    60
    Newfane, NY
    New Holland T1110
    Default Re: Tz22da
    I've looked high and low on parts breakouts from Messicks for this part you showed above. I cannot find anything close. It almost looks like part of a seat slide or something where you could adjust your seat. I'll keep looking when I have a chance. Everything works? All your levers work, seat slides back and forth ok and pedals work fine? This has me stumped. There are no numbers on it or anything?
Similar Threads
  1. Winter with tc34da and tz22da
    By expedoman55 in forum New Holland Owning/Operating
    Last Post: 11-23-2011, 01:44 PM
  2. TZ22DA
    By fresca11 in forum New Holland Owning/Operating
    Last Post: 06-26-2011, 02:15 PM
  3. What is a fair asking price for my TZ22DA
    By deermedic in forum New Holland Buying/Pricing
    Last Post: 05-27-2010, 09:17 AM
  4. tz22da hydralics seem weak
    Last Post: 08-03-2009, 06:30 PM
  5. NH TZ22DA vs 'bota 2350
    By diverdownrick in forum Buying/Pricing/Comparisons
    Last Post: 06-19-2006, 01:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
