brianb33
I had fuel starvation issues and ultimately drained and cleaned fuel tank, replaced fuel lines, cleaned fuel bowl top assembly, and replaced the fuel filter. That solved about 80% of the problem. It still can be slow to start at first, and rpms will not increase for a few minutes until the engine warms up even with the throttle full open. It seems to want to bog down more under a load. My biggest issue now is it tends to stall when I stop and reduce throttle to minimum, especially if it is still in gear. After that it is very difficult to start, even tried bleeding fuel line with no luck. After it sits overnight it will start up as usual. When it happened today I replaced the fuel filter and I had to loosen the ring to allow air to escape so the fuel would flow and fill the bowl. I seemed to remember in the past if I cranked the engine the fuel filter would fill rapidly but it didn't today. About the only thing I haven't done is clean/replace the fuel pump. Can that be the problem? Is it possible to disassemble the fuel pump and clean it out?
