Results 1 to 1 of 1
  1. #1
    New Member
    Join Date
    May 2008
    Posts
    20
    Default Ford 4000 steering arm and spindle repair
    My right front hub on my Ford 4000 has either twisted or bent. Now, the tire rubs against the steering arm. I took off the tire and the hub is is twisted back toward the steering arm. I am pretty sure the bushings and bearing are toast because there is a lot of play in the spindle. I attached pictures. For reference, the left tire is pointing straight ahead.
    I tried to take the steering arm off, but it won't budge. The manual says to use tool 1002, 951, and 625. Not sure what those are, is there something else I can use? Also, do I need to remove the hub assembly to take the spindle out?
    Attached Thumbnails Attached Thumbnails Ford 4000 steering arm and spindle repair-101_7778-jpg   Ford 4000 steering arm and spindle repair-101_7775-jpg
Similar Threads
  1. Ford One Arm Loader 19-209 (711) & Ford 4000
    By rwacho in forum Ford Vintage Tractors
    Last Post: 08-08-2013, 09:32 AM
  2. '68 Ford 4000 SOS repair cost
    By sweep in forum New Holland Ag Tractors
    Last Post: 03-14-2012, 05:50 PM
  3. Ford 1720 spindle and steering arm sloppy
    By double hunter in forum New Holland Owning/Operating
    Last Post: 08-08-2011, 05:15 PM
  4. YM240 spindle and steering repair
    By 284 International in forum Yanmar
    Last Post: 01-02-2011, 11:52 AM
  5. Ford 4000 Selectospeed Tach Repair?
    By hc99 in forum New Holland Owning/Operating
    Last Post: 05-24-2009, 10:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
