Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Jun 2013
    Posts
    2
    walnutport, pa
    Ford 555
    Default 555 starter how do I get the third bolt off
    Hi new to the form. Trying to get the starter off. How do I get to the third bolt and do I need to take off the fuel pump to slide out the starter? My starter has both battery cables going to it. I would like to short out the selenoid but not sure which bolts to bypass it. With the key off there is a full battery voltage at the terminals on the starter. When trying to start the voltage goes down to almost nothing. Is that normal? If I can try the starter while its on the unit I could rule it out or know it needs replacement. I believe the unit is a 1980-1983. Its just a 555 no letters after it. 3 cyl diesel. Its at such a bad location I can't even make out what connections are on the solenoid. I do not have the shop manual. I really could use some help. I have serviced this baby for 11 years, I would hate to have to pay someone to come fix it. I don't have many qualified ford guys around me and the one gets $00 just to show up.
    Thanks,
    Phil
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,577
    Lincoln County, NC need new avatar!
    Just a Scag
    Default Re: 555 starter how do I get the third bolt off
    Voltage drop like that can indicate either a massive draw by the starter motor or a bad battery cable connection somewhere along the way. To remove the third bolt, use the following: 9/16" 6 point 3/8 drive flex socket, 6" long 3/8 drive extension and a ratchet. The injection pump doesn't have to come off to get the starter out. it may be helpful to remove the fuel filter so you can better see/feel what is going on. Replace at least one of the other two bolts while fussing with the third one; that keeps the starter in place.
    if you have another loader available to lift your loader up and securely prop in the raised position, things get much easier to deal with. Above all, be safe.
    Spring is the season of optimism.
  3. #3
    New Member
    Join Date
    Jun 2013
    Posts
    2
    walnutport, pa
    Ford 555
    Thanks, any idea what to short out on the solenoid to verify it is the starter? Guess I will give it a try again today. Will have to buy a flex socket, don't have one of those.
    Thanks,
    Phil
  4. #4
    Join Date
    Jan 2012
    Posts
    623
    Winchester Ky
    Allis Chalmers ED 40
    The signal wire from start circuit is a spade terminal on the top front of the solenoid, just inboard of the positive battery cable post. The wire comes from behind the starter and plugs on from the front side. It's usually about a 12 G wire, white with a red stripe. Solenoid has a male spade, can be either a standard size or the larger size depending on starter make. Hard to see among all the crud, and even harder to reach, especially with framework in front. Removing the fuel filter will help a lot, but it's still not easy.
  5. #5
    New Member
    Join Date
    Jun 2013
    Posts
    1
    sandusky ohio
    ford 555a backhoe
    Hi Phil, did you have to remove the fuel injector pump to remove the starter? I have a ford 555a backhoe and was able to remove the old starter by taking it all apart in pieces, but can't put the new one back in because it hits against the fuel injector pump. Would appreciate any help from anyone...Thanks
  6. #6
    Join Date
    Sep 2000
    Posts
    9,577
    Just a Scag
    Quote Originally Posted by crduckdil View Post
    Never had to remove the IP to R&R the starter on ANY 3 cylinder Basildon built Ford engine. Period.
  7. #7
    Gold Member Ultradog MN's Avatar
    Join Date
    Jun 2006
    Posts
    276
    Twin Cities, MN
    Ford 3000, Ford 4450, Ford 4200
    You just need the right 3/8 ratchet and combination of extensions and or deep socket. Starter will come out without removing anything else.
    Leave the top outside bolt tight untill last.
    Helps to hold your mouth just the right way.
    “What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do something about them”
    Henry Ford
  8. #8
    New Member
    Join Date
    Sep 2013
    Posts
    15
    Cripple Creek,CO
    Ford/CAT/AC/
    Quick note to all I have / had the same problem after many busted fingers here is what worked for me:
    Get a 3/8" or smaller drive to get the bolt off closest to the block , leave the top outside one in, remove the fuel filter, then you have to get the Solenoid off theres 2 phillips screws and if an original Lucas M50g there is a nut that holds the Solenoid to the starter remove that. Then you can wiggle the Solenoid so that it clears the injection pump point the teeth end of the starter straight down and pull the starter up and out , will share my results of putting a new one on when the part gets here
  9. #9
    Join Date
    Sep 2000
    Posts
    9,577
    Just a Scag
    Quote Originally Posted by bestes1206 View Post
    Way too much to go through. I use s 9/16" 3/8 drive flex socket, 6" extension, ratchet. Done.
  10. #10
    New Member
    Join Date
    Sep 2013
    Posts
    15
    Cripple Creek,CO
    Ford/CAT/AC/
    depending on the starter you have there are some lucas m50's that will not clear the injection pump period without removing the Solenoid but to each their own
Similar Threads
  1. 555 DTC on slopes
    By dginter in forum Farmtrac
    Last Post: 08-20-2013, 10:53 AM
  2. 555 on slope
    By dginter in forum Owning/Operating
    Last Post: 06-06-2013, 10:27 AM
  3. Dropped starter bolt in engine JD 5045D
    By Korx in forum John Deere Owning/Operating
    Last Post: 06-13-2012, 06:00 PM
  4. Grapple Bodozer Bolt-On Bucket Claw/ATI Bolt-On Grapple
    By Engine66 in forum Attachments
    Last Post: 11-06-2007, 12:57 PM
  5. Replies: 5
    Last Post: 08-15-2007, 03:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
