Results 1 to 3 of 3
06-23-2013, 09:36 PM #1
- Join Date
- Jun 2013
- Posts
- 5
- Location
- Clarksville,tn
- Tractor
- Ford 3600
1977 ford 3600 trouble starting
Tractor was left out in the weather for about 4 years with cover over exhaust. This is a diesel tractor and I believe it may be seized up.
I was told by a friend to jack up the rear end, put it in high range and high gear and try to push or move a rear tire. Tractor is loaded up on a tall gooseneck trailer with a bush hog attached.
Any help would be appreciated....thanks...
06-24-2013, 03:54 AM #2
- Join Date
- Nov 2008
- Posts
- 550
- Location
- Central Illinois
- Tractor
- Many JD
Re: 1977 ford 3600 trouble starting
I think I would remove the valve cover and make sure there are no stuck valves before trying to turn the engine over. Jacking up a and trying to jerk a wheel will work but I would rather put a breaker bar on the nut on the end of the crank shaft and pull it over that way. If you can bar it over two turns by hand I would hit it with the starter. You may also want to change all the filters and put fresh fuel in as well.
06-24-2013, 08:48 AM #3
- Join Date
- Jun 2006
- Posts
- 274
- Location
- Twin Cities, MN
- Tractor
- Ford 3000, Ford 4450, Ford 4200
Pull the injectors and pour half a cup of Marvel Mystery oil down each cylinder. Let it sit for a week.
Then put a battery in it and bump the starter a couple of times. Likely that will unstick her.
If it breaks free and turns over it'll spew MMO everywhere but that can be cleaned up.---------------------------------------------------
“What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do something about them”
Henry Ford
Similar Threads
Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions?
By PorkChopsMmm in forum Ford Vintage TractorsReplies: 570Last Post: 07-09-2016, 01:58 AM -
Having trouble starting my 1973 Ford 2000 diesel
By JosephFatherof6 in forum New Holland Owning/OperatingReplies: 6Last Post: 04-05-2013, 02:11 PM -
Trouble starting my Ford 8?? (I can't figure out the exact model)
By bennevis in forum Ford Vintage TractorsReplies: 29Last Post: 05-04-2012, 06:33 PM -
1977 ford 550
By johninrochester in forum Construction EquipmentReplies: 1Last Post: 11-25-2011, 02:07 PM -
Backhoe ford 1977 550
By johninrochester in forum New Holland Owning/OperatingReplies: 1Last Post: 11-23-2011, 07:23 PM
