Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Default Re: 1910 Short Circuit
    In all your posting, you have not mentioned if you have a voltmeter. You said you tested the fuses, but didn't describe the method. Anyhow, if the fuse is good, you should have power on the output side. If you have power there, then check the light switch for power coming to it (turned off). Then turn the switch on and check for power leaving the switch. My guess is that you'll either find the fuse was mis-diagnosed as good or the light switch is toasted.
    Jim
  2. #12
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,400
    Lincoln County, NC need new avatar!
    Just a Scag
    Quote Originally Posted by Kopierguy View Post
    Am I missing something? Glow plug circuit has not been in the discussion.
    The key switch controls the glowplugs; the glowplug load is carried by the fusible link and ignition switch. Whether discussed or not, a fault in the glowplug circuit could be the cause of the problems. As yet, the OP hasn't explained how any of the troubleshooting has been done, or whether he has and knows how to use a VOM or even a test lamp. Corroded fuseholders are common on old tractors, too.
    Spring is the season of optimism.
Similar Threads
  1. Pulse VS Short circuit MIG break test.
    By LD1 in forum Welding
    Last Post: 10-01-2011, 10:09 AM
  2. Warning- short circuit possibility
    By DiskDoctr in forum Mahindra Owning/Operating
    Last Post: 04-07-2010, 09:05 AM
  3. Hyd motor & Ram in one circuit; How? Help Please
    By Hows she now in forum Hydraulics
    Last Post: 11-22-2009, 06:17 PM
  4. Worklight Circuit
    By GotSnow in forum Kubota Owning/Operating
    Last Post: 02-05-2008, 06:02 PM
  5. BX2200 short in headlight circuit
    By 149owner in forum Kubota Owning/Operating
    Last Post: 12-27-2005, 01:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
