Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    New Member
    Join Date
    Jun 2012
    Posts
    8
    Midway, Texas
    Ford 4610, Kubota ZD321, Gator 6x4, Honda AT350X
    Default It Won't Stay Up
    I have a 1982 Ford 4610 tractor with a front end loader. It has a position control lever and a draft control lever. When I have the six foot mower attached, it will not stay where I put it with the position lever. The mower and the lever itself drops. Is there a friction adjustment or is this a hydraulic problem? It just started doing this recently. It has always stayed put in the past. Any ideas are appreciated.
  2. #2
    Elite Member Sysop's Avatar
    Join Date
    Jun 2013
    Posts
    3,056
    Fairmont, WV
    Mahindra 4035HST purchased 2013 - Craftsman 42" HST purchased 2003
    Default Re: It Won't Stay Up
    When using the mower the draft control should be off. Draft is for stuff that actually engages the soil so if the soil gets hard it can lift your plow or whatever tool you're working with to prevent damage. With or without draft, the tool on the back should never go lower than the position set by the position control. If your position control is all the way down and draft is adjusted to lift your mower to position, once you start it will drop to the lowest position when there are no forces on the draft sensor.
    If all of the above is understood, draft is off (all the way down), and the position control is not all the way down but your mower still drops to the lowest position, it is unfortunately a hydraulics issue with the lift.
  3. #3
    Super Member
    Join Date
    Nov 2009
    Posts
    5,758
    Indiana
    Bobcat
    wow, that's not what I thought of when I read the title of this thread.......
  4. #4
    New Member
    Join Date
    Jun 2012
    Posts
    8
    Midway, Texas
    Yes, I keep the draft all the way down. The attached mower and the lever drop like a rock. It lifts fine but just won't stay there. I was sure hoping there was a magic friction adjustment I could tighten up to keep it from falling. As long as I hold the lever in place, the implement stays up. When I take my hand off, it drops. Thanks.
  5. #5
    Join Date
    Jun 2013
    Posts
    3,056
    Fairmont, WV
    The whole lever and all drops? That's not what I was thinking about. What I had in my mind was the levers stayed in position and the unit still dropped.
    If it stays up as long as the lever stays in position, it sounds like it's just an issue with the lever system, not the hydraulics. Perhaps some sorta tension spring broke or something. I'm not familiar with your exact unit to make a guess.
  6. #6
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    In the illustration below, look at Item #33. It's a nut that can be tightened to increase the friction on your lever. If that does not work, then you may have worn friction discs. They are Item #34 and part number 81717214 from your New Holland dealer. Messicks.com has them for $1.90 each. Some people make their own friction discs out of thin leather, but I'd suggest buying the NH part at such a cheap price. Probably, you won't need it, just adjust the nut a half turn and you'll be back to normal.
    It Won't Stay Up-nh4610liftassy-jpg
    Jim
  7. #7
    Join Date
    Jul 2013
    Posts
    587
    nz
    no tractor now
    I had the same problem with a walking position control lever. It was worn out friction pads on the lever. Replaced the friction pads, now lever stays put .
  8. #8
    Super Member
    Join Date
    Aug 2004
    Posts
    6,778
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Add some VIAGRA!
    Sorry, could not help myself.
  9. #9
    Super Member TomSeller's Avatar
    Join Date
    Jan 2013
    Posts
    8,694
    JD, Massey, Kubota, Case
    Default
    Then what if it stays up more than 4 hours?
  10. #10
    Veteran Member xring100's Avatar
    Join Date
    Dec 2012
    Posts
    1,470
    Livingston County, Michigan
    Kubota M8540, ZD1211 60"
    Default
    Quote Originally Posted by TomSeller View Post
    Then what it stays up more than 4 hours?
    Only if you add too much
    Dave
Similar Threads
  1. Mowing TC 29 PTO WILL NOT STAY ENGAGED
    By JOEY29842 in forum New Holland Owning/Operating
    Last Post: 06-11-2013, 02:32 PM
  2. Is TYM here to stay?
    By CrashandBurn in forum Buying/Pricing/Comparisons
    Last Post: 09-02-2010, 11:34 PM
  3. Mid PTO will not stay ingauged
    By richard83 in forum Kubota Owning/Operating
    Last Post: 09-30-2006, 07:39 PM
  4. PLEASE help looking to stay under 20K
    By coryip in forum Kioti Buying/Pricing
    Last Post: 03-23-2004, 04:39 PM
  5. 3 pt. won't stay up
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 06-10-2000, 02:01 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
