Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,428
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: TC29 3 PT hitch help needed
    Quote Originally Posted by redman135 View Post
    Re your pto shaft. The telescope section needs greasing, it looks dry. Also when did the universal joints get greased last?
    I did not notice that, but yeah, dry as a bone, and I bet the U joints are dry too.
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  2. #12
    Elite Member rlgustafson's Avatar
    Join Date
    Dec 2012
    Posts
    3,525
    Weimar, Texas
    NH TL-100A with Bush Hog 5045 FEL, WR Long 3rd function, LS XR4155HC w/FEL, WR Long 3rd Function.
    Default
    After you get PTO shaft cleaned up and greased you might consider replacing the yellow plastic cover around shaft. Cover keep dirt and debris out of grease and keep things and people from getting caught up in spinning shaft. I think they can be sourced thru Tractor Supply and implement dealers. You might just buy a complete new shaft with guards, chains, etc. cheap insurance
    http://www.vapormatic.com/content/ne...pto-shaft.ashx
    Rick
    Trying to work smarter instead of harder with Technology and Horsepower!
  3. #13
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    I'm of the opinion that the cover on a rotary cutter PTO shaft is a waste of money. Nobody should ever have a reason to get anywhere near to a rotating shaft on a rotary cutter. It's not like a post-hole auger or chipper where you work close to an operating shaft. I think the same way about a tiller or other piece of PTO driven equipment. It's my opinion for what it's worth. Some safety features are overkill in my estimation. The points about lubing the shaft are valid, but I can't be sure the U-joint isn't greased. I'm not sure that Ridgewalker has had the mower or tractor very long.
    One thing for sure, the extendable arms on the 3PH need lots of attention. Don mentioned that the "dust cover" was missing off the left side. That is NOT a dust cover. It is a spring loaded release sleeve that operates the bolt that drops into the slot on the extendable arm section. The front of the cover has a spring under it. You press down on the front of the cover and it pivots on the front pin and raises the locking bolt out of the slot. When you release the sleeve, the spring pushes it back up and locks the extendable arm when it moves forward to the operating position. Don's left side extendable link must be locked in place or the locking bolt is loose enough to move up and down by hand. If that's the case, only gravity and weight of the bolt is holding it in place. I can see on the left arm that the front pivot pin is completely gone as is the sleeve and spring. See the illustration below.
    TC29 3 PT hitch help needed-extenablelink-jpg
    Jim
  4. #14
    Platinum Member Ridgewalker's Avatar
    Join Date
    Jan 2008
    Posts
    932
    St. Francois Mountains of Missouri
    NH TC29
    Quote Originally Posted by jinman View Post
    Now we're cookin' on the front burner...I am missing the springs. I couldn't figure out what held the assembly in the correct position
    and it has to be the missing springs. Thanks Jinman!
    PS, I will be greasing the PTO.
    "Ride due west of the sunset, turn left at the rocky mountains."
Similar Threads
  1. CatII to 3 point hitch - help needed
    By dixie in forum Attachments
    Last Post: 02-18-2010, 10:22 PM
  2. B7510 Quick Hitch Needed
    By rx4fun in forum Kubota Buying/Pricing
    Last Post: 08-24-2009, 11:21 PM
  3. Kubota BX25 4-point hitch needed???
    By stuarth in forum Kubota Owning/Operating
    Last Post: 12-08-2008, 09:29 PM
  4. Tractor Quick Hitch help needed.
    By Warren in SC in forum Attachments
    Last Post: 09-22-2006, 08:57 PM
  5. 4110 3pt hitch measurement needed, please
    By 2nstonge in forum John Deere Owning/Operating
    Last Post: 03-20-2005, 12:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
