Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Platinum Member Ridgewalker's Avatar
    Join Date
    Jan 2008
    Posts
    932
    St. Francois Mountains of Missouri
    NH TC29
    Default TC29 3 PT hitch help needed
    My Brush-hog isn't parallel with the back of my tractor and I can't figure out
    what I am doing wrong. I can get it to line up but once I start cutting it
    ends up running outside my right wheel on an angle.
    I'm not sure if I have the hookups on correctly and would appreciate any schooling I can get.
    See attached.
    Thanks in advance!
    TC29 3 PT hitch help needed-tractor-jpg
    "Ride due west of the sunset, turn left at the rocky mountains."
  2. #2
    Elite Member rlgustafson's Avatar
    Join Date
    Dec 2012
    Posts
    4,715
    Weimar, Texas
    NH TL-100A with Bush Hog 5045 FEL, WR Long 3rd function, LS XR4155HC w/FEL, WR Long 3rd Function.
    Default
    Does your tractor have stabilizers on 3 point arms? Can you take a picture looking down at arms from above?
    Rick
    Trying to work smarter instead of harder with Technology and Horsepower!
  3. #3
    Bronze Member 5picker's Avatar
    Join Date
    Jul 2004
    Posts
    97
    Western PA, USA
    TC33D Hydrostatic 7308 Loader
    Default Re: TC29 3 PT hitch help needed
    Make sure your 3PH arm pins are not in the slotted holes. With the pins in the slotted holes, the implement can swing significantly from side to side.
    Center the 'hog and put the pins in the holes that most closely line up.
    Note: you 'may' have to apply a slight amount of side pressure to get one side or the other to align with a hole.
    PS... I also see in your photo the arms are still slightly extended... put your implement all the way down and back up until the extensions retract and latch.
    They are only made to extend for ease of hook-up and not meant to be used that way during operation.
    New Holland TC33D - 7308 Loader - 72" LuckNow 3PH snow blower with home built hydraulic chute rotation - 84" Woods RFM - 60" Woods Brushog - Home built ballast box - Home built landscape rake - 3PH post hole digger - Home built pallet forks - Home built receiver hitch - Home built soft cab - Home built boom
  4. #4
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    I'll bet your blades turn CCW; therefore, the blades cut grass on the leading edge and tend to push the cutter to the right. Since they are not cutting (as much) on the rear half-arch, the mower tends to go to the right. Offset your cutter as far to the left as you can with the stabilizer pins so that it is held as far left as possible. Also, you might make sure the cutter us running level. If it leans to the right, it will make the natural right tendency worse.
    One more thing to look at is how much lower your cutter is in front than in the rear. Most cutters are designed to run 1" to 2" lower in front, but if you are dipping down more, the pressure to move right will be even more. How thick the grass is and how heavy the materials will also push your mower right. Of course, having sharp blades also will make the cutter pull less to the right.
    Jim
  5. #5
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,175
    Branson, Mo.
    Kioti DK35se Hydrostat
    Well it looks to me that you do not have the right lower telescoping link pushed back in. Drop the cutter on the ground, to create a little resistance and reverse the tractor to click the right link back in place.. Or at least that is what I think I see.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  6. #6
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Nice catch, James and 5-picker. The pin is not correct also. It may be too big to drop into the slot and lock the arm in the non-extended position. I think he has lost the bolt and replaced it with the pin. I'd suggest going back to a smaller diameter bolt.
    Jim
  7. #7
    Join Date
    Jan 2008
    Posts
    932
    NH TC29
    Thanks guys, those are new pins that I just bought, I will replace them.
    Plus I didn't realize the links were not built to run extended. Add to that I am
    missing a dust cover off the left side. I'll be using all your tips so "Thanks!" again.
    rlgustafson if stabilizers are the pins that go into one of a series of holes connected to the
    3 pt then yes.
    One more question; Do I have the links in right side up? I can get the link to go into the
    arm but it doesn't stay there. I guess the pin has something to do with that and having one that's too large
    isn't helping.
  8. #8
    Super Member tcreeley's Avatar
    Join Date
    Feb 2011
    Posts
    7,957
    Hudson, Maine
    2003 NH TC30
    oil and grease might be good- looks dry
    NH TC30, 7308 loader, 7' snowbear plow, 5' hiller, 5' tillovator (agrisupply), International Agritech 5' towable Bushhog. dumping carryhall, camo brush trailer, 8 hp Trencherman backhoe, International disk harrow, International single plow, Sears ZTL 7000, 8hp Roto Hoe Shredder'nChipper, CubCadet 524 snow blower, CubCadet rear tine tiller, working forge
  9. #9
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    The pin looks like a 5/8" pin. I'd try 1/2". If it is 1/2", I'd try 7/16" or 3/8". It has to fit easily in that slot and should be grade 5 or 8. An aircraft locking nut (nylock) on a bolt is needed to make the pin a tiny bit loose, but retain the nut. I rarely lube mine and they've worked since 2001.
    Jim
  10. #10
    Join Date
    Jul 2013
    Posts
    584
    nz
    no tractor now
    Re your pto shaft. The telescope section needs greasing, it looks dry. Also when did the universal joints get greased last?
Similar Threads
  1. CatII to 3 point hitch - help needed
    By dixie in forum Attachments
    Last Post: 02-18-2010, 09:22 PM
  2. B7510 Quick Hitch Needed
    By rx4fun in forum Kubota Buying/Pricing
    Last Post: 08-24-2009, 10:21 PM
  3. Kubota BX25 4-point hitch needed???
    By stuarth in forum Kubota Owning/Operating
    Last Post: 12-08-2008, 08:29 PM
  4. Tractor Quick Hitch help needed.
    By Warren in SC in forum Attachments
    Last Post: 09-22-2006, 07:57 PM
  5. 4110 3pt hitch measurement needed, please
    By 2nstonge in forum John Deere Owning/Operating
    Last Post: 03-20-2005, 11:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
