Results 1 to 8 of 8
  1. #1
    Join Date
    Jan 2002
    Posts
    1,569
    Colorado
    2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
    Default 7308 FEL, standard bucket vs heavy duty bucket
    Regarding the 7308 FEL, what is the difference between the standard bucket and the heavy duty bucket? Anyone have pictures of them? Is there a difference in the capacity, or is the HD one just stronger? Thanks.
  2. #2
    Gold Member jcollins's Avatar
    Join Date
    Jun 2001
    Posts
    259
    Houston, TX
    Default Re: 7308 FEL, standard bucket vs heavy duty bucket
    HD Bucket has a rolled top edge, reinforced side cutting plates, and welded on cutting edge that is predrilled to mount another bolt on cutting edge to. Attached is a picture of a heavy duty bucket. The picture is taken of just one side of it so that you can see more clearly the difference.
    Attached Images Attached Images
  3. #3
    Join Date
    Jun 2001
    Posts
    259
    Houston, TX
    Here is a standard duty
  4. #4
    Super Member Inspector507's Avatar
    Join Date
    Mar 2002
    Posts
    5,915
    Central Ohio
    Jason,
    On the 54" bucket on my TC18 w/12LA loader, It has a 2x2 steel channel at the top. Is this a standard bucket??
    Seems pretty HD to me [img]/forums/images/graemlins/grin.gif[/img]
  5. #5
    Join Date
    Jan 2002
    Posts
    1,569
    Colorado
    Jason - Thanks a lot! Great pictures and comparison.
  6. #6
    Join Date
    Jun 2001
    Posts
    259
    Houston, TX
    54 in. Standard Material Bucket
    54 in. High Capacity Light Material Bucket
    These are the only two 54" buckets available for the 12LA loader. What you have is probably the stadard bucket. The high capacity buckets are made out of some really light stuff; I would image for just snow remove but I don't have much experiance with that it TX! [img]/forums/images/graemlins/grin.gif[/img]
  7. #7
    Join Date
    Jan 2002
    Posts
    1,569
    Colorado
    Jason, So, I'm assuming there is no difference in the capacity - is that correct? What is the difference in the weights of the buckets? What is the price difference? Thanks.
  8. #8
    Join Date
    Jan 2002
    Posts
    1,569
    Colorado
    In case anybody else needs this info, page 40 in the 7308 FEL manual shows the standard 60" bucket weight at 211 lbs and the heavy duty 60" bucket weight at 240 lbs.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
