john4153
- Joined
- Jun 2, 2010
- Messages
- 73
- Tractor
- Case DX40
My tractor is a 2003/2004 Case DX40 with 550 hours, which is about identical to the TC40DA.
Yesterday, temp gauge went into the red while mowing. Air temp was 70°F +/-. It appeared to be a thermostat that failed closed. Replaced that. Also replaced sensor. Both removed parts tested OK on the bench. I did a resistance/temperature profile on the removed sensor. FWIW, here it is (the 210°F is an estimated value):
Does anyone know what the resistance is supposed to be? More important, what should the voltage at the wire to the sensor relative to ground be? Is it 5V, as suggested by automotive sensors? If so, I am concerned the voltage regulator on the PCB may have failed. Is there any way to test the gauge easily before replacing it. That is, given a certain resistance to ground, what should it read? What is the usual operating temperature of the coolant? My local dealer doesn't know.
Thanks,
John
Thanks,
John
