Results 1 to 2 of 2
  1. #1
    Join Date
    Feb 2001
    Posts
    93
    Saranac, New York
    TC35D
    Default 16 LA loader hidden grease fittings
    After 3 years I found 2 grease fittings on the 16LA that I never knew were there even though the manual grease page shows it as point #3. Who reads manuals.. You can ONLY get at it or see it when the loader is off. It is the bottom hole on the large upright that slips into the large pin on the tractor mid-mount support. It should only need grease every 2 years but don't neglect it like I did. Frank
  2. #2
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Default Re: 16 LA loader hidden grease fittings
    I've greased mine twice. I have my loader off and will grease it again right before I put it back on the tractor. The lower spring-loaded seat only moves when installing or detaching the loader, so I think that's the only reason for the grease. ...I guess [img]/forums/images/graemlins/confused.gif[/img]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
