Specs on NH 16LA FEL
   / Specs on NH 16LA FEL #1
have_blue
Eunice, Louisiana
L4400
Troube in paradise. Dealer is having trouble getting a new Woods FEL for me, so I am considering the 16LA and taking a serious price hit.
Can anyone anyone point me to specs on this loader? The NH web site has almost nothing.
Thanks in advance.
   / Specs on NH 16LA FEL #2
lift ht 105in
dump angle 58degrees
rollback 30 degrees
lift cap 1800lb on a TC35
breakout force 3186 lbs TC35
appx weight 1100lbs
clearance full height w/ bucket dumped 81.5in
digging depth 6.5in
It's a nice loader. Off and on easy. Joystick is integrated into tractor. Get the quick attach plate, bucket and forks - you won't be sorry.
Mark
   / Specs on NH 16LA FEL #3
Here are the two pages from the Owner's Manual (attachment to this post and the next one). Mark covered most everything, but make sure you get the heavy duty bucket also. I think it is standard with the quick-attach, but if you opt to not have that, I recommend you stay away from the standard bucket. The HD bucket has holes predrilled for adding a cutter bar or tooth bar.
   / Specs on NH 16LA FEL #4
2nd page of specs...
   / Specs on NH 16LA FEL #5
One more thing...
I know how money can be tight, but this loader was designed to be used only on Class III Boomers and everything about it is a perfect match for your tractor. I could not look you in the face and recommend another loader after having mine. It is truly a perfect match. I think you will be saying you are glad you picked the 16LA for many years to come. I give my wholehearted endorsement to this loader. Probably nothing else you buy for your tractor will repay you as much as this loader.
</font><font color="blue" class="small">( Probably nothing else you buy for your tractor will repay you as much as this loader. )</font>
Doh!
GRRRRRRRRRRRRRR!
Why do you want to go and cause trouble for? /forums/images/graemlins/confused.gif
I think I'll call my dealer tomorrow. Thanks for the info Jim...I guess!
Jim,
I got the 16LA, and I have you to blame.
I twisted the dealer's arm and he gave me nice discount. I only paid $300 more for the 66" LA than the 66" Woods. Because the tractor was undelevered, it gave me the final leverage I needed.
   / Specs on NH 16LA FEL #9
</font><font color="blue" class="small">( I got the 16LA, and I have you to blame. )</font>
You're welcome! "Blame" accepted. /forums/images/graemlins/laugh.gif I don't think you can find a single person on TBN with a 16LA who has had anything bad to say about it. It's embarrassing how much I like my loader. It also sounds like you made yourself one heck of a good deal. /forums/images/graemlins/cool.gif
Just look at the loader in the attachment. Is that beautiful or what? ...it works better when you wear a blue shirt too. /forums/images/graemlins/smile.gif
Jim, I bet your dog is blue. /forums/images/graemlins/wink.gif
Hey, you can't bend the booms. They're already bent.
Just kidding. I think the 16LA looks elegant in its own way.
I came that close -><- to getting the Bush Hog FEL. What a strong, bulletproof scoop it has! Since I have no granite blocks or depleted uranium to load, I opted for something lighter for the tractor's front end. I'll keep all the heavy stuff on the back.
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
TMA (A49461)
TMA (A49461)
