Results 1 to 8 of 8
  1. #1
    Join Date
    Mar 2010
    Posts
    196
    East Texas
    Default Ford 4610 Electrical Issue
    Thought I'D post this here since it is a Ford issue. Today I had an unusual electrical problem. First start of the day. I turned the key to start and engine made an attempt to start but did not start. I turned the key to off then back to start. This time I had no indicator light on instrument panel and no power to start. Nothing, just silence. I went to the shop and got my battery tester and multimeter for troubleshooting. I tried the key again but still nothing. Battery tested good, could not reach fuse box cause you have to remove hood. I could not reach positive battery connection cause FEL was installed and fuel filter is in the way. So I did not do too much checking. The tractor was in the barn and not much work space on right side.
    So I decide to try key again and now I have indicator lights. I go around to try another start and engine starts right up. I worked the rest of the day and engine has started right up no hesitation. So, I do not know what to make of this no start. Is there a self resetting circuit breaker in system? Switch going bad? Any thoughts on this problem will be appreciated.
    I am parking tractor in open field in case it dies on me so I can try to remove FEL for easier work access.
  2. #2
    Veteran Member jimmysisson's Avatar
    Join Date
    Jul 2005
    Posts
    1,648
    W.Mass
    1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
    Default
    Ign switch or more likely poor battery cable or cable grind connection. Good luck.
    Jim
    "Anything worth doing is worth doing slowly" Mae West
  3. #3
    Veteran Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,059
    Western Montana
    New Holland TD95D, Ford 4610 & Ferguson TO-30
    Default Re: Ford 4610 Electrical Issue
    Quote Originally Posted by jimmysisson View Post
    Jim
    I agree with Jim. Check the battery cables and the starter solenoid connections as well as the chasis ground connection. Might also look at connections on the key switch. Occaisonally the transmission neutral start switch will stick. So try wiggling the hi-lo lever if it happens again.
  4. #4
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    7,591
    Eastern NY
    Case 885, Ford 4000
    Quote Originally Posted by Jerry/MT View Post
    Agree with all. Get in the habit of leaving the range shifter in N so the NSS will close and not freeze open as when the range shifter is in high or low and temps drop with condensation under the shift cover.
    We have too much gun control.
    What we need is more idiot control.
  5. #5
    Join Date
    Mar 2010
    Posts
    196
    East Texas
    Thanks all for the replies. Now that you mention cables I did have a cable issue a while back. I noticed during start up that smoke was coming from cable connected to starter. I cleaned and added dielectric and tightened. No more smoke. Yesterday it started without any hesitation. I am going to remove FEL to access the cables and check them out. Ford decided to use black cables for + n - so it was not clear on the routing. I believe - goes to the starter connection which is unusual. The other appears to go to the starter solenoid. I will know better once I remove the FEL and review the wiring diagram. Thanks again.
  6. #6
    Join Date
    Sep 2000
    Posts
    7,591
    Eastern NY
    Case 885, Ford 4000
    The battery ground cable may very well go to a 8MM lug the front of the starter case. The Battery positive cable goes to the top large post on the start solenoid.
  7. #7
    Join Date
    Mar 2010
    Posts
    196
    East Texas
    Quote Originally Posted by RickB View Post
    That is the way it looks. I will know better once I remove the FEL.
    Well, now I believe it may be rodents. I have had a problem with rodents 2 times in the past. I have had to do some wiring repair. Today I was using the tractor and on the last start up, I noticed that my fuel gauge moved to full fuel. With power off it moves to half full. This is a new movement pattern and it may be rodents have chewed into the wiring. I will have to take the hood off and pull the instrument panel to check it all out.
  8. #8
    Join Date
    Mar 2010
    Posts
    196
    East Texas
    Well, the rodents got me again. I pulled the instrument panel and found chewed wires. Repaired and now fuel and temperature gauge work again. I am not sure if they chewed any of the more hidden wires. The tractor has been starting since the no-start problem. Time will tell.-image-jpg
Similar Threads
  1. 4610 Surging Issue- Fixed!!
    By OleMiss in forum John Deere Owning/Operating
    Last Post: 02-23-2014, 12:11 AM
  2. Replies: 10
    Last Post: 05-29-2013, 09:36 PM
  3. FORD 4610 MUFFLER ISSUE
    By LastSTRAW in forum Parts/Repairs
    Last Post: 08-05-2012, 08:22 PM
  4. Ford 3000 electrical issue
    By kempersw in forum Ford Vintage Tractors
    Last Post: 10-31-2010, 10:35 AM
  5. Ford 3000 reading hot - electrical issue
    By kempersw in forum Parts/Repairs
    Last Post: 10-30-2010, 03:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
