2003 TN75S won't go into forward or reverse
   / 2003 TN75S won't go into forward or reverse #1
wholley
Cleveland, Texas
TN75S
Thank you in advance for your help.
I have a 2003 TN75S and it has been setting for several months and I went to use it this morning and it will not go into forward or reverse. There are no warning lights on the dash indicating any problems.
   / 2003 TN75S won't go into forward or reverse #2
I have the same model. On mine, if I put the shuttle lever in neutral, press the clutch and put it in gear, let the clutch out with the shuttle in neutral, then redepress the clutch and put the shuttle in forward or reverse with the clutch depressed and then let the clutch out she goes. It doesn't do this all the time. Give it a try...it can't hurt.
   / 2003 TN75S won't go into forward or reverse #3
Welcome from Wisconsin
