Jerber, if you haven't gotten the loader off yet, here is the procedure.
1. Lower loader on a flat, level surface with the bucket flat.
2. Shut off the tractor and relieve any pressure in the hydraulic system by moving the loader lever in all directions several times.
3. Remove the bolt 15 at the bottom of each loader post and let the latching plate 12 hinge down. If there is a pin in the loader frame hook 11, remove the pin.
4. Start the tractor and, using the loader hydraulics, roll the loader frame forward and down off of the front loader frame hooks. The front of the frame becomes the parking stand.
5. Shut off the tractor and relieve the pressure in the loader hydraulics. If the hoses are not marked, paint 3 of the couplers a different color to allow matchup when hooking up. Any system that works to identify the correct hose hook up will work. Disconnect the hoses. Back the tractor away from the loader.
Hook up in reverse order.
