Page 4 of 4 FirstFirst 1234
Results 31 to 33 of 33
  1. #31
    New Member followjr's Avatar
    Join Date
    Apr 2014
    Posts
    6
    Athens, Tx
    1969 Ford 4000 3cyl Diesel
    Default
    Quote Originally Posted by ebayollis View Post
    When I change the seals can it be done from the outer hub in or will I have to split the whole rear end?
    I've got a 1969 European model with the heavy front axle. I replaced the left rear axle seal last year. You have to remove the housing from the differential and take everything out of the housing. I left my tire on. I removed everything that would prevent it from coming off, i.e. Fender, stabilizer chain etc. Have plenty of clean hydraulic fluid jugs handy for when you drain it. I removed all the bolts holding the housing on. Then standing inside of the tire with my back to it I was able to work it out and then lay the wheel down therefore pointing the axle upward. It wasn't all that bad, just heavy work. Pay close attention to how everything comes out. I had to buy a 1 5/16" socket to remove the main bolt down inside. I then had to rig up a press using a small bottle jack and a chain to pop the housing off of the axle shaft. The seal is attached to the housing. I ruined one new seal because I didn't realize how it went on. It doesn't press on but you do have to press it down( used same press rig to do this) and then peen it all the way around to get it to stay on. Sorry for the long post.
  2. #32
    Join Date
    Apr 2014
    Posts
    6
    Athens, Tx
    Default
    Quote Originally Posted by followjr View Post
    getting ready to buy a ford 4000-image-3085648372-jpg
    getting ready to buy a ford 4000-image-3445742881-jpg
  3. #33
    New Member
    Join Date
    Apr 2014
    Posts
    24
    spruce pine
    ford 4000
    Default Re: getting ready to buy a ford 4000
    Hey thanks for the long post...helps me out a lot!
Similar Threads
  1. Was ready to buy
    By freewookie in forum Buying/Pricing/Comparisons
    Last Post: 10-23-2013, 09:29 AM
  2. Buying Advice getting ready to buy
    By dc53 in forum Power Trac
    Last Post: 11-04-2012, 06:49 PM
  3. Well, I'm ready to buy, but...
    By AHNC in forum Kubota Buying/Pricing
    Last Post: 11-11-2009, 06:37 PM
  4. Ready to buy ?
    By Beavis in forum Buying/Pricing/Comparisons
    Last Post: 09-18-2007, 09:22 PM
  5. Ready to buy
    By Bill_Ryan in forum John Deere Buying/Pricing
    Last Post: 06-02-2001, 08:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
