sawtooth
- Joined
- Sep 19, 2007
- Messages
- 1,192
- Location
- Eden NC
- Tractor
- Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
Ok I think I have a issue. Let's start from the top. I bought this tractor and seems to run and crank very well. But I first did a coolant flush and got rust colored coolant out. Filled with clean water plus radiator flush ran per directions and got more rust coolant out. Did again and more very rust colored coolant. Radiator pretty clean last drain but engine coolant very dirty. On top of this first drain out I got a lot more water than second and third drain out. It's like system is not completely filling back up and water is over core in radiator. Seems like less water in engine block. Also I don't see water moving in radiator but not sure I should. Next interesting part So backing up when I got the tractor I noticed temp gauge ran right up to red but would never go into red. I removed radiator cap and no boiling out etc. So I purchased a new 188 thermostat and now temp goes a little into the red. Next I decide to get a new temp sending unit and now it runs from little red mark (1st quarter of gauge) to middle of gauge as you would expect. See picture! My questions now are (1) why am I still getting rust out. (2) why can I now not get enough water back into the system (3) should I see water flowing in the radiator (4) And do the pics I took showing inferred thermometer look like normal temp readings. These are on the block not the manifold. Rear of engine definitely hotter that front. Is this normal? Please help!
