Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Join Date
    Jan 2010
    Posts
    160
    Paducah (West) Kentucky
    Ford 3000 (early, 65-67), Bolens G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
    Default Re: Ford 3000 front wheel bearing zerk issue
    OK, I was off by a few hours, (My memory is not as good as it was in the past) the Ford Owners Manual I was referring to says front bearings are a 600 hour service.
    (Its still a crappy description in the book and nothing in the service manual) I admit I know little which is why I ask here.
    So for me front wheel bearing greasing is a once a year service, I think my points are still valid.
    Attached Thumbnails Attached Thumbnails -lube-front-bearing-600-hrs
  2. #12
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    8,297
    Eastern NY
    Case 885, Ford 4000
    Not sure what points you are talking about. You've proved it impossible to thread a zerk into an unthreaded tapered blind hole. And you can't retain service interval information read from a manual. What Am I missing?
    We have too much gun control.
    What we need is more idiot control.
  3. #13
    Bronze Member HakanTh's Avatar
    Join Date
    Dec 2010
    Posts
    64
    Sweden
    Ford 4000
    Thanks johneic, I will keep that in mind.
    By the way, zerks are good when they work as they should. Best way is to screw a bolt and a fibre washer in the hole, instead of the zerk. When it is time to grease you change to a fresh zerk, grease and switch back to the bolt again. If you put zerks into the steel caps, they are not only exposed to dirt and water, you will sooner or later have one smashed or dented.
    I am not sure about the need for it on a hub in normal use, better to take apart, clean and repack with fresh grease.
    Reminds me of the, never used, small grease guns that came with every new chainsaw for greasing the bearing in the sword's tip. As an oldtimer said: "If you never had dirt in there before, you will get it when you pump with that thing".
  4. #14
    Join Date
    Nov 2012
    Posts
    235
    Klamath Falls, Oregon
    Branson 2400H, Ford 861, Kubota 5100E
    600 hours?
    I'd bet the grease in there is what left the factory...
    Slow speeds, not much weight, probably good for another few decades.
    Regrease if it makes you feel better, but probably not needed.
  5. #15
    Join Date
    Jan 2010
    Posts
    160
    Thanks for the help HakanTh and bajabum, I never thought of them breaking off and a few decades will be the most this retired bookkeeper will need, I will be in the earth by then. Thanks again for the helpful tips, I worked in an office my whole life and never did things like this, I need the good ideas from here.
  6. #16
    Join Date
    Dec 2010
    Posts
    64
    Sweden
    Ford 4000
    Glad to help with the little I know.
    These machines do not have modern technology in them, so they can be understood pretty easily. It is PBL (Problem-based learning) all over, "Good judgment comes from experience, experience comes from bad judgment."
    By the way, you have got a Private Message.
  7. #17
    Platinum Member bumperm's Avatar
    Join Date
    Oct 2013
    Posts
    962
    Gardnerville, NV
    Kubota B3350 cab & BX24
    When drilling thinner metal that will be tapped for threads, instead of drilling the hole to the size called for by the tap spec, drill a much smaller hole. Then tap a tapered awl into the hole to enlarge to correct hole size. This will create a inward "cone" that will provide much more threaded surface.
    bumper
  8. #18
    Join Date
    Dec 2010
    Posts
    64
    Sweden
    Ford 4000
    Great tip, bumper!
    You will get something like this (mouse over to zoom the image)?:
    Weidmüller 0687900000 FM 4/TS35 from Conrad Electronic UK
Similar Threads
  1. Replacing Front Wheel Bearing on Ford 2600
    By Taylodp in forum New Holland Owning/Operating
    Last Post: 11-07-2013, 11:54 PM
  2. Pilot Bearing And Release Bearing On A Ford 3000
    By Shepp in forum New Holland Owning/Operating
    Last Post: 09-17-2012, 12:34 AM
  3. Ford 3000 (1971) front wheel shimmy
    By 88xjwheeler in forum New Holland Owning/Operating
    Last Post: 12-04-2011, 03:37 PM
  4. Ford front wheel bearing
    By stevewatr in forum Parts/Repairs
    Last Post: 11-30-2011, 08:47 AM
  5. front wheel bearing
    By braulsy in forum Yanmar
    Last Post: 05-31-2005, 09:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2016 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
