Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Join Date
    Jan 2010
    Posts
    228
    Paducah (West) Kentucky
    JD 3038e, Bolens-Iseki G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
    Default Ford 3000 front wheel bearing zerk issue
    I have the service and owners manuals, they are not helpful
    I have do not have a zerk on either front wheel, I have a variety of zerk sizes. I tried to thread in two different sizes, could not get one to thread.
    Question
    1) Is the center of the spindle, just outboard of the cotter pin, where the zerk should be?
  2. #2
    New Member
    Join Date
    Jul 2014
    Posts
    14
    Pleasant Valley, NY
    Ford 1920
    Default Re: Ford 3000 front wheel bearing zerk issue
    Can you take a picture?
  3. #3
    Bronze Member HakanTh's Avatar
    Join Date
    Dec 2010
    Posts
    67
    Sweden
    1969 Ford 4000
    I think you mean a zerk on the hub cap, correct me if I am wrong.
    There are two types of caps:
    One is made of cast iron and has a zerk, http://www.oie.se/Archive/Bilder/Pro...250&height=250
    One is made of steel and has no zerk, http://www.oie.se/Archive/Bilder/Pro...250&height=250
    The steel type was fitted on most tractors, the one with zerk is intended for use in environments where the front axle gets under water. You could then easily chase the water out from the bearings by pressing grease through them.
  4. #4
    Join Date
    Jan 2010
    Posts
    228
    HakanTh you hit the nail on the head for me, Big Thanks for your great answer!, But this raises more questions:
    I have the steel one, so:
    1) I have to pull the wheel and manually repack the bearings every 50-100 hours?
    2) Is it worth $40 ($20x2) to buy the cast iron ones? (This is kind of a stupid question as I mow about 10 hours a week in spring, and run it maybe 2 hours a week in winter) Well worth $40.00 not to pull my wheels once a month or so April to September.
    New Dust Cap for Ford New Holland Tractor 2000 3000 2110 2120 2150 2300 230A | eBay
    I also checked Amazon, nothing there with a zerk tap.
    3) Anyone know of a lower cost one tapped for a zerk?
    4) Can I drill and tap my steel one to accept a zerk or is it too thin? or am I missing something else?
    PS I got confused by the owners manual as it just shows an overhead view of the tractor with an arrow pointing to the middle of the front wheel (denoted grease), duh!
    My service manual says noting about lubrication (As it should).
    Ford 3000 front wheel bearing zerk issue-3000-hub-zerk-003-jpgFord 3000 front wheel bearing zerk issue-3000-hub-zerk-004-jpg
  5. #5
    Join Date
    Jan 2010
    Posts
    228
    HakanTh if you ever want something from the U.S.A. where the seller will not ship overseas, contact me, I sell a lot on ebay and ship overseas, I will arrange with you to have it delivered to me and I will ship to you at my cost!
    John
    PS, Not a scam, I take Paypal and/or could make a listing just for you on ebay.
  6. #6
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    if you want zerks in your caps drill and tap for them. BTDT.. takes 5 minutes.
    sometimes you get lucky and find a later hub with zerk in hub.
    souNdguy
    sent from my NOKIA LUMIA
  7. #7
    Join Date
    Jan 2010
    Posts
    228
    Thanks Soundguy!
  8. #8
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,955
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Quote Originally Posted by johneic View Post
    I have never seen a front wheel bearing that required greasing every 50 hour or even ever 5000 hours. If you properly pack the wheel bearing when installing them and put plenty of bearing grease inside the hub, you should never have to grease it again. The only thing I have ever had to do for wheel bearing is jack up the wheel, check for slack in the bearing, if it is a bit loose, remove the cotter pin in the castle nut and tighten it a bit. Spin the wheel, it should roll freely but not be loose on the wheel spindle.
    Unless you are routinely running your tractor with water over the front axle, that should be all you ever have to do. You may at some point have to replace the grease seal at the back of the hub and/or bearings after several thousand hours.
    I don't know where you came up with the requirement for repacking the wheels every 100 hours.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  9. #9
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,572
    Lincoln County, NC need new avatar!
    Just a Scag
    Question
    No. The grease zerk may be installed in the hub, never the spindle. You are trying to install a zerk in a machined center Used in the manufacturing process. It leads nowhere and has no threads.
    Spring is the season of optimism.
  10. #10
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    remember.. ford hub seals are dust seals. also the screw in cap is less than water tight.
    grease is cheap!
    souNdguy
Similar Threads
  1. Replacing Front Wheel Bearing on Ford 2600
    By Taylodp in forum New Holland Owning/Operating
    Last Post: 11-07-2013, 10:54 PM
  2. Pilot Bearing And Release Bearing On A Ford 3000
    By Shepp in forum New Holland Owning/Operating
    Last Post: 09-16-2012, 11:34 PM
  3. Ford 3000 (1971) front wheel shimmy
    By 88xjwheeler in forum New Holland Owning/Operating
    Last Post: 12-04-2011, 02:37 PM
  4. Ford front wheel bearing
    By stevewatr in forum Parts/Repairs
    Last Post: 11-30-2011, 07:47 AM
  5. front wheel bearing
    By braulsy in forum Yanmar
    Last Post: 05-31-2005, 08:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
