2001 TC40 will not go in gear
   / 2001 TC40 will not go in gear #1
jimmmy86
dresden,tn.
TC40 new holland 2001
I have a 2001 NH TC40 IT WILL NOT GO IN GEAR WHILE TRACTOR IS RUNNING WHEN PRESSING CLUTCH TRACTOR WILL NOT GO IN GEAR THIS PROBLEM JUST STARTED OWNED THIS TRACTOR NEW FROM THE DEALER THIS IS THE FIRST PROBLEM I HAVE HAD IT HAS 560 HOURS ON IT ANY HELP WOULD BE APPERICAITED .
   / 2001 TC40 will not go in gear #2
Has it been setting a while.
Sounds like a possible stuck clutch.
WAS LAST USED ON 09/01/14
IF IT IS A STUCK CLUTCH WHAT WOULD I HAVE TO DO TO GET IT UNSTUCK
   / 2001 TC40 will not go in gear #5
If the tractor was used as recently as a few days ago, its doubtful that is your problem.
   / 2001 TC40 will not go in gear #6
Have you ever adjusted the clutch pedal? The procedure is in the Operator's manual for my 2003.
Does it feel normal when you step on the clutch?
Is all the clutch pedal linkage in place and looks normal--not bent, nothing stuck in there?
Everything looks normal with the linkage and adjustment rod and clutch pedal arm
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
Mini Excavator 9 Piece Attachments (New/Unused) (A59225)
Mini Excavator 9...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
