Coolant leak question TC33D
   / Coolant leak question TC33D #1
sherpa
North Carolina Mountains
2004 NH TC33D & 2014 NH Boomer 24
I have a coolant leak on my TC33D. I attached a picture so you can identify where the leak is. It is on the right side of the engine just to the right of my oil filter. I need to know if this plug has threads or is pressed into the engine block? It is in line with the freeze plugs. Can this plug be tighten or should I just use some stop leak?
Thanks,
sherpa
   / Coolant leak question TC33D #2
Based on its shape, hex, I'd guess it has threads. The picture at Messicks shows threads on it. $32.60.
   / Coolant leak question TC33D #3
It is a common problem. The hose connector is made from zinc and will react with iron. I replaced mine when the tractor was nearly new with brass and it has yet to leak after these years. Pictures will follow very soon.
   / Coolant leak question TC33D #4
Here is what it looks like and the tool to get it out with. I milled a slot into a heavy impact socket to get it out in one piece. You can just cut the bib part off and use a 1-1/16 deep 6 point socket too.
   / Coolant leak question TC33D #5
Where can you get the all brass version and what's it called? :)
   / Coolant leak question TC33D #6
Thanks so much for this info!
I will order my parts and get them here before I cut the barb off.
sherpa
TAKEUCHI TB235-2 EXCAVATOR (A52709)
TAKEUCHI TB235-2...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2020 FREIGHTLINER...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
John Deere 5103 (A53317)
John Deere 5103...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
