mroberts5
(About a New Holland 1920 - 2100hr - 100 w/ me. I usually run 4WD active, not sure of previous owners.)
So I'm just about done w/ my clutch replacement (actually much easier than I expected), and the only parts that's given me a hard time is the FWD drive shaft.
Two issues, one minor, one larger:
Minor: The rear coupling is just about seized on to the output shaft from the transmission. I'm going to remove the drop box to get it off and clean everything up.
Larger issue: The front end of the drive shaft, the front collar, and the input shaft to the front axle are SHOT!
See the pictures below. Not only are the splines worn nearly to nothing, but coupling pin has been banging around so bad that its worn a grove in both shafts and has nearly worn it self out (see photos)
Fixing it is easy (provided I can find the parts), but my main concern is: why did this happen? Something must be out of alignment to cause this kind of wear. Any clues on where to start looking?
I saw one comment on another post about worn axle pivot bushings, but I'm not too familiar with how this will cause the issue.
Thanks.
Thanks.
